Failed to magrating 7940 ip phones between 2 clusters remotely
Aug 11th, 2012
Just failed to magrating 7940 ip phones between 2 cluster yesterday
Some information of 2 clusters
Cluster A has just been upgraded from 6.1.2 to 8.6.2-21900 , and Cluster B upgraded from 8.5.1 to 8.6.2- 21900.
Cluster A used for the Shanghai Office , Cluster B used for others cities
We planned to magrate about 40 7940 iphones and 100 6921 iphones registered in Cluster A to Cluster B  but finally failed.
following is what we had done .
1  changed "PREPARE CLUSTER FOR ROLLBACK TO PRE 8.0 “ from false to true  in CUCM A
2  restarted TVS and TFTP service
3  reset those  iphones
4   change the DHCP settings on the remote SWITCH
as the result ,  all 6921  IP phones  successfully magrated between 2 clusters but 7940 failed
Is there any mistakes we made  or some other points we should take attention??
pgcristovam Sun, 08/12/2012 - 20:04
Try delete CTL/ITL files manually in 7940 ip phones!
Qiyu Bao Sun, 08/12/2012 - 20:37
hi pqcristovam
  i have not  fund CTL/ITL files in 7940 ip phones..
  i had just test for magrating 7940 ip phone  between 2 clusters in the lab of Shanghai office successfully, but failed in the remote office with the same way.
