Warning message
VM-FEX with Nexus 5500
Aug 11th, 2012
  • Bronze, 100 points or more
While configuring vcenter to N5K connection(svs connection just like in Nexus  1000v) we need to connect only thru vpc primary switch i.e. connect  command under svs connection <name> only applied on vpc primary  switch. What happens when VPC primary switch is reloaded and secondary  becomes operational primary. I tested this but it seems that while primary  switch is going thru reboot second switch does not automatically bring  up vcenter connection. Also while primary is going thru reboot process  the whole vpc domain breaks connection to vcenter.
pod5-n5k-1# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 55
Peer status                     : peer link is down
vPC keep-alive status           : Suspended (Destination IP not reachable)
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary, operational primary
Number of vPCs configured       : 0
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1718 down   -
pod5-n5k-1# sh svs connections
Local Info:
connection MyVC:
    ip address: 10.2.8.51
     remote port: 80
    vrf: management
    protocol: vmware-vim https
    certificate: default
    datacenter name: MyDC
    extension key: Cisco_Nexus_1000V_1813219752
    dvs name: MyVMFex
    DVS uuid: -
     config status: Disabled
    operational status: Disconnected
    sync status: -
    version: -
Peer Info:
connection MyVC:
    remote port: 80
    vrf: management
      certificate match: TRUE
    dvs name: MyVMFex
    DVS uuid: 54 b6 2c 50 47 50 92 f9-b3 32 c1 b0 a9 28 df aa
     config status: Enabled
    operational status: Connected
After primary came up with operational secondary both switches loose the svs connection to vcenter See below
Local Info:
connection MyVC:
    remote port: 80
    vrf: management
     dvs name: MyVMFex
    DVS uuid: -
    sync status: -
    version: -
Peer Info:
connection MyVC:
     remote port: 80
    vrf: management
     dvs name: MyVMFex
pod5-n5k-2# sh svs connections
pod5-n5k-1# sh vpc
Legend:
vPC domain id                   : 55
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
1    Po1718 up     1,1422
Local Info:
connection MyVC:
    remote port: 80
    vrf: management
     dvs name: MyVMFex
    sync status: -
    version: -
Peer Info:
connection MyVC:
    remote port: 80
    vrf: management
    dvs name: MyVMFex
    DVS uuid: -
My question is how to make sure when secondary switch becomes operational primary it initiates the vcenter connection?
Overall Rating: 4 (1 ratings)
krun_shah Sat, 08/11/2012 - 14:26
Also one more thing,
After vpc primary switch came up and became operational secondary none of the switches cannot connect to vcenter
pod5-n5k-2# sh vpc role
vPC Role status
vPC role                        : primary, operational secondary
Dual Active Detection Status    : 0
vPC system-mac                  : 00:23:04:ee:be:37
vPC system-priority             : 32667
vPC local system-mac            : 00:05:73:be:eb:bc
vPC local role-priority         : 1
pod5-n5k-2# config t
Enter configuration commands, one per line.  End with CNTL/Z.
pod5-n5k-2(config)# svs connection MyVC
pod5-n5k-2(config-svs-conn)# no connect
pod5-n5k-2(config-svs-conn)# connect
pod5-n5k-2(config-svs-conn)# exit
pod5-n5k-2(config)# sh svs connections
Local Info:
connection MyVC:
    remote port: 80
    vrf: management
    dvs name: MyVMFex
    DVS uuid: -
    sync status: -
    version: -
Peer Info:
connection MyVC:
    remote port: 80
    vrf: management
    dvs name: MyVMFex
    DVS uuid: -
pod5-n5k-1# sh vpc role
vPC Role status
vPC local system-mac            : 00:05:73:ca:f7:01
vPC local role-priority         : 10
pod5-n5k-1# config t
pod5-n5k-1(config)# svs connection MyVC
pod5-n5k-1(config-svs-conn)# no connect
pod5-n5k-1(config-svs-conn)# connect
pod5-n5k-1(config-svs-conn)# sh svs connections
Local Info:
connection MyVC:
    remote port: 80
    vrf: management
    dvs name: MyVMFex
    DVS uuid: -
    sync status: -
    version: -
Peer Info:
connection MyVC:
    remote port: 80
    vrf: management
    dvs name: MyVMFex
    DVS uuid: -
Simon Vaillancourt Mon, 08/13/2012 - 12:51
  • Cisco Employee,
Hi Krunal,
Which version of NX-OS are you running on these Nexus 5000?
In short, according to the NX-OS 5.2(1)N1(1) L2 Config Guide, you need to configure the SVS Connection to vCenter on both switches and activate it on both, but only the primary will actually connect. In case of failure, once the secondary assumes the operational primary role, the configured connection should become active. I haven't tested this myself, but that's my understanding of the documentation:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/layer2/521_n1_1/b_Nexus_5000_Layer2_Config_521N11_chapter_010001.html#task_6534F78F2BB549CA83C52508FBE81F50
Let me know if this helps and feel free to reach out to me as I'm the Cisco Channel SE supporting OnX in Canada.
Best regards,
Simon
Related Content
