No SSH/Telnet to Cisco 800 series router
Answered Question
Aug 13th, 2012
I have an issue with several 800 series routers.
This router was upgraded to 12.4(24)T7 and it is since this that we have started seeing the issue. It was subsequently downgraded.
router#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(24)T6, RELEASE SOFTWARE (fc2)
When I turn on telnet and ssh debugging I see sessions as the arrive on the internal interface, but not externally.
router#sh deb
TCP:
  TCP Packet debugging is on for address x.x.x.x, port number 2222, incoming packets
TELNET:
  Incoming Telnet debugging is on
SSH:
  Incoming SSH debugging is on
As you can see, tcp debugging shows my external connection come in and I get a TCP reset back. x.x.x.x was my office public IP, y.y.y.y is the customer's router public IP.
Aug 13 11:34:39.957: tcp0: I LISTEN x.x.x.x:62614 y.y.y.y:2222 seq 2937972774
        OPTS 24 SYN  WIN 65535
Aug 13 11:34:39.957: TCP: sent RST to x.x.x.x:62614 from y.y.y.y:2222
It should be listening by the looks of things.
router#sh control-plane host open-ports
Active internet connections (servers and established)
Prot               Local Address             Foreign Address                  Service    State
tcp                        *:22                         *:0               SSH-Server   LISTEN
tcp                        *:23                         *:0                   Telnet   LISTEN
tcp                        *:23         192.168.0.240:33329                   Telnet ESTABLIS
tcp                      *:2222                         *:0               SSH-Server   LISTEN
tcp                      *:1723                         *:0                     PPTP   LISTEN
udp                     *:55724                         *:0                  IP SNMP   LISTEN
udp                       *:123                         *:0                      NTP   LISTEN
udp                       *:161                         *:0                  IP SNMP   LISTEN
udp                       *:162                         *:0                  IP SNMP   LISTEN
The IP y.y.y.y is negotiated with IPCP.
interface Dialer0
ip address negotiated
ip access-group 100 in
ip mtu 1492
ip inspect DEFAULT100 out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname [email protected]
ppp chap password 0 xxxxxx
router#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     y.0.0.0/32 is subnetted, 1 subnets
C       y.y.y.y is directly connected, Dialer0
     a.a.a.0/32 is subnetted, 1 subnets
C       a.a.a.a is directly connected, Dialer0
C    192.168.0.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 is directly connected, Dialer0
Access list 100 explicitly permits my office subnet, as does access list 23.
line vty 0 4
access-class 23 in
privilege level 15
login local
rotary 1
transport input all
transport output all
And rotary 1 maps to 2222.
I see the same problem with telnet and ssh (on the rotary and port 22) from outside, however inside it works without a hitch. I've tried messing with the login local and access lists to no avail. I suspect that IPCP is significant in this.
'Shaun' in this thread appears to have the exact same issue.
Many thanks to anyone who takes the time to help me with this. If you need any more info please let me know.
Tom
Correct Answer by owaisberg about 4 years 5 months ago
Hi Tom.
I have identical to yours setup. All the same just no ip inspect on my routers.
Anyway, I did a workaround for that issue which works just fine. You can try that and
let me know. Idea is to create loopback interface on the router and then build a static
NAT entry from the public address to the loopback address. I did that for SSH and it
works like a charm.
Let me know if that helps.
Thanks again,
Oleg
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 08/13/2012 - 05:10
Post complete config.
Note you don't need ip tcp mss'adjust on dialer. Alos not needed, ip access-group and inspect.
tom.salmon Tue, 08/14/2012 - 08:17
Current configuration : 5436 bytes
! Last configuration change at 11:11:24 BST Mon Aug 13 2012 by admin
! NVRAM config last updated at 11:01:33 BST Mon Aug 13 2012 by admin
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname customer-name
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200
no aaa new-model
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
clock save interval 24
dot11 syslog
ip source-route
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip domain name customer-name.local
ip name-server 192.168.0.100
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
username admin privilege 15 password 0 password
username userb password 0 1
username userc password 0 2
username userd password 0 3
username usere password 0 4
username userf password 0 5
username userg password 0 6
username userh password 0 7
username useri password 0 8
username userj password 0 9
username userk password 0 0
username userl password 0 -
username userm password 0 =
archive
log config
  hidekeys
ip ssh port 2222 rotary 1
ip ssh source-interface Dialer0
interface ATM0
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template1
ip unnumbered Vlan1
ip nat inside
peer default ip address pool dialin
no keepalive
ppp encrypt mppe auto required
ppp authentication ms-chap-v2 ms-chap
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap password 0 password
ip local pool dialin 192.168.0.240 192.168.0.250
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.240 25 y.y.y.y 25 extendable
ip nat inside source static tcp 192.168.0.240 80 y.y.y.y 80 extendable
ip nat inside source static tcp 192.168.0.240 110 y.y.y.y 110 extendable
ip nat inside source static tcp 192.168.0.240 443 y.y.y.y 443 extendable
ip nat inside source static tcp 192.168.0.100 3389 y.y.y.y 3389 extendable
ip nat inside source static tcp 192.168.0.28 3389 y.y.y.y 3390 extendable
ip nat inside source static tcp 192.168.0.33 3389 y.y.y.y 3391 extendable
ip nat inside source static tcp 192.168.0.2 3389 y.y.y.y 3392 extendable
ip nat inside source static tcp 192.168.0.240 3389 y.y.y.y 3395 extendable
logging trap debugging
logging origin-id hostname
logging x.x.x.x
access-list 23 permit 192.168.0.0 0.0.0.255
access-list 23 permit a.b.c.d 0.0.0.63
access-list 23 permit e.f.g.h 0.0.0.7
access-list 23 permit i.j.k.l 0.0.0.127
access-list 25 permit x.x.x.x 0.0.0.127
access-list 100 permit tcp host x.x.x.1 any eq telnet
access-list 100 permit tcp any host y.y.y.y eq 3390
access-list 100 permit tcp any host y.y.y.y eq 3391
access-list 100 permit tcp any host y.y.y.y eq www
access-list 100 permit tcp any host y.y.y.y eq 443
access-list 100 permit tcp any host y.y.y.y eq smtp
access-list 100 permit tcp any host y.y.y.y eq pop3
access-list 100 permit tcp any host y.y.y.y eq 1723
access-list 100 permit gre any any
access-list 100 permit icmp any any echo
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any host y.y.y.y echo-reply
access-list 100 permit icmp any host y.y.y.y time-exceeded
access-list 100 permit icmp any host y.y.y.y unreachable
access-list 100 permit ip e.f.g.h 0.0.0.7 any
access-list 100 permit ip a.b.c.d 0.0.0.63 any
access-list 100 permit udp any host y.y.y.y eq ntp
access-list 100 permit ip e.f.g.1 0.0.0.7 any
access-list 100 permit ip x.x.x.x 0.0.0.127 any
access-list 100 deny   ip any any
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
snmp-server community public RO 25
snmp-server ifindex persist
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
rotary 1
transport input all
scheduler max-task-time 5000
ntp server 192.43.244.18
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Thanks Paolo,
Hope this helps.
Tom
tom.salmon Wed, 08/15/2012 - 05:01
I have tried that and it doesn't resolve the issue. We nee the access list on the dialer as we wish to restrict access to some devices to certain subnets. Our subnet has an allow rule in the access list and this definitely works.
I have also tried removing list 23 from the vty but, again, this has had no impact on the issue.
Paolo Bevilacqua Wed, 08/15/2012 - 13:34
Just to clarify, even if that does not resovle, consider that when you have NAT, it's impossible for externa packets to come in unless a translation had been created from inside. That is why ACL is not needed.
Anyway., another cause can be the rotary statement, try removing it.
tom.salmon Thu, 08/16/2012 - 02:46
Hi Paolo,
My concern is due to the static NAT translations which port forward to servers. In particular, I have seen brute force attacks on Microsoft remote desktop which is why I firewall these to only permit trusted subnets.
I've tried removing the rotary but this has made no improvement. It was only added during the troubleshooting process.
Thanks for your patience.
Tom
Jeff Van Houten Sun, 08/19/2012 - 15:34
Have you tried taking the access-class off the vtys?
owaisberg Mon, 08/20/2012 - 19:46
Hi Tom,
Seems like an IOS issue because I have the same problem on c1841 after did an upgrade from my c1751
where the same config worked perfectly. As soon as I went to c1841 I get this problem, and again...config
is virtually identical. I keep digging and let you know if I find the fix.
Thanks again,
Oleg
tom.salmon Tue, 08/21/2012 - 01:09
Hi Oleg,
Do you get an IP by IPCP? I can't test with a static IP on my dialer as the router is on a customer site and I can't cause disruption. I'm going to get out a spare 877 and try the config on that. If it exhibitsthe same issue I'll try using a static IP and see if that helps.
Tom
Correct Answer
owaisberg Tue, 08/21/2012 - 07:09
Hi Tom.
works like a charm.
Thanks again,
Oleg
Richard Burts Wed, 08/22/2012 - 21:58
I have seen this problem before. When you specify NAT with an extended access list which includes permit any it impacts remote access. The solution is simple. Since your access list is only specifying the source address and permit destination any then you can easily rewrite it as a standard access list. I suggest that you rewrite access list 102 as access list 2 specifying the same source network and then use it in your NAT configuration.
Rick
owaisberg Wed, 08/22/2012 - 22:09
Rick,
Thanks for your reply. In fact I did try to play with an ACLs flipping them to standard and
it had no effect - Telnet and SSH still were treated the same with TCP RST sent back to
the initiator. As I mentioned, the workaround I implemented provides what I needed, so I
can think of that case as closed. Not sure about Tom if he tried that or not or found other
solution.
Thanks again,
Oleg
tom.salmon Tue, 09/04/2012 - 02:03
Oleg,
I have tried your workaround in two locations and in both cases it has worked.
Hopefully Cisco will actually fix this bug in the next version of 12.4(24)T.
Thanks for your help!
Tom
Paolo Bevilacqua Mon, 10/22/2012 - 04:27
It is not a bug, it's unlikely to be ever 'fixed', and IOS 12.4 is not developed anymore.
converged Thu, 05/21/2015 - 01:48
We think this is a bug, and would like to see a bug ID so we can then check for sure which IOS releases are and are not affected.
We think it is a bug as it behaves differently, in different IOS versions.
After an IOS upgrade, you find yourself unable to telnet to the router.
We think we have seen it with:
c870-advipservicesk9-mz.124-24.T4.bin
and:
c180x-advipservicesk9-mz.150-1.M7.bin
because we're seeing it in IOS 15 the rack IOS 12.4 is end of line doesn't matter...
Neil
Corner Speed Fri, 01/13/2017 - 07:00
Was this issue ever classified as a bug? Appreciate this is an old thread, but I have never come across this before until yesterday. I upgraded a 800 series router with 12.x  to an 887VA with 15.3 code.
I had this exact issue where SSH was refused on the outside interface even with no ACLs on the vty lines or dialer. The only way I could permit SSH from outside was by port-forwarding the the public ip to a loopback with the ip nat inside statement on the loopback interface.
Corner Speed Fri, 01/13/2017 - 01:18
No sir,
there are some specific static nats to inside hosts and an overload statement for the dialer:
R1#sh run | in nat
ip nat inside source list 1 interface Dialer1 overload
R1#sh ip access-lists
Standard IP access list 1
       10 permit 192.168.1.0, wildcard bits 0.0.0.255
Richard Burts Fri, 01/13/2017 - 06:56
Thanks for clarifying that your NAT does not include a permit any. Your problem must relate to something else and I am not clear what that would be. I am glad that you found a work around.
Rick
francisgamo Mon, 10/22/2012 - 07:15
I Think this is the reason why you cannot telnet/ssh your router.
regards,
Francis
francisgamo Mon, 10/22/2012 - 01:27
Thanks for this post it helps me a lot, it fixed my problem. i used extended nat so that i could access my router trough remote. thanks again
