Warning message
Excessive %ARP-3-DUP_VADDR_SRC_IP: arp [4769] log-entries
Answered Question
Aug 13th, 2012
I'm looking into a problem, which involves excessive logentries containing the message below:
%ARP-3-DUP_VADDR_SRC_IP:  arp [4769]  Source address of packet received from 0000.0c07.ac00 on Vlan814(port-channel4095) is duplicate of local virtual ip, 10.10.215.1
The attached drawing shows the topology between the distribution-switches and the OTV-AED's.
The logentry repeats itself every 10 seconds, and is only seen on the Root-Bridge. The other distributionswitch is unaffected by this. The behaviour itself doesn't seem to pose any stress on the N7K, as generel forwarding and day-to-day operation is not affected in any way. However, periodic spikes in CPU are recorded, with NetStack and STP being the top-talkers. The overall stp-topology is stable, when taking a detailed look in the various vlans. TC-notifications are rarely seen and usually only when we would expect to see them.
I've gone through releasenotes for v5.2 and tried to find something with the BugToolKit, but so far no luck. I've found various posting on the net, with others having similar issues, only theese very mostly related specifictly to Hsrp. So far, I've been unable to find any incident related to OTV.
I'm only seeing this behaviour for vlans extended across OTV. All OTV-AED's have the required filtering in place, prohibiting the learning and/or advertising of fhrp information, both at L2 and L3. The filtering works, since we've successfully managed to isolate Hsrp at the two sites. There's nothing to suggest occasional split-brain scenarios, Hsrp is stable and working as expected. Futhermore, we're not seeing this issue on any other vlans not extended across OTV. Nor are we seeing theese logentries recorded on any other Port-channels than thoose connecting the OTV-edge devices to their parentswitches.
The configured vlan-filter on the OTV devices are as listed below:
mac access-list OTV-BLOCK-L2
  10 remark * HSRPv1 and HSRPv2 *
  11 permit any 0000.0c07.ac00 ffff.ffff.ff00
  12 permit any 0000.0c9f.f000 ffff.ffff.f000
  20 remark * VRRP *
  21 permit any 0000.5e00.0100 ffff.ffff.ff00
  30 remark * GLBP *
  31 permit any 0007.b400.0000 ffff.ff00.0000
ip access-list OTV-BLOCK-L3
  11 permit udp any 224.0.0.2/32 eq 1985
  12 permit udp any 224.0.0.102/32 eq 1985
  20 remark * VRRP *
  21 permit 112 any 224.0.0.18/32
  30 remark * GLBP *
  31 permit udp any 224.0.0.102/32 eq 3222
mac access-list OTV-FORWD-L2
  10 remark * Everything else *
  11 permit any any
ip access-list OTV-FORWD-L3
  11 permit ip any any
  12 permit icmp any any
vlan access-map OTV-BLOCK 10
        match mac address OTV-BLOCK-L2
        action drop
        statistics per-entry
vlan access-map OTV-BLOCK 20
        match ip address OTV-BLOCK-L3
        action drop
vlan access-map OTV-BLOCK 90
        match mac address OTV-FORWD-L2
        action forward
vlan access-map OTV-BLOCK 91
        match ip address OTV-FORWD-L3
        action forward
vlan filter OTV-BLOCK vlan-list 814-817,2020
Interestingly, the OTV aed does have the hsrp-mac in its CAM-table, though I would expect the above filter to drop that.
So far, the only valid conclusions I have come to is either a STP-issue or somehow, the above filter is not programmed correctly into the hardware and thus not processed correctly.
Any thoughts will do.
/Ulrich
Correct Answer by bonestorm about 4 years 9 months ago
Hi Ulrich,
An update from my end.  I found a command that can be added to the SVI to suppress this error.  It is :
     no ip arp gratuitous hsrp duplicate
See this link:
https://supportforums.cisco.com/thread/2136520
I have tried it in our environment and it works fine.  Might be easier than configuring arp filters.
Mark
Overall Rating: 5 (3 ratings)
bonestorm Thu, 08/23/2012 - 17:30
Hi Ulrich,
I had the same issue in my environment.  I have two 7ks at each of two sites, so four in total.  These 7ks are split into two VDCs - one for the M1 card, and the second for the F2 card.  The data centre SVIs live on the F2 VDC.  OTV is running on the M1 VDC.
After changing the vPC peer-link from one port channel to another on the F2 card I got the duplicate address error. Since I am not yet in production I was able to try a number of different things to make the error go away.
What I eventually found was that shutting the overlay interfaces at one of the sites, then un-shutting them fixed the issue.  Not such a good fix whilst in production!
I don't have anything to advise on why this happens, but regardless, this is one possible fix.
Mark
Ulrich Hansen Fri, 08/24/2012 - 00:17
Hi Mark,
I'll give it a try and see what happens.
Thanks for replying.
/Ulrich
Ulrich Hansen Mon, 10/01/2012 - 07:19
Well,
As it seems, an ARP-filter did the trick. Applied the following filter on the OTV-Edge devices, which seem to have solved the problem:
arp access-list HSRP_VMAC_ARP
  10 deny ip any mac 0000.0c07.ac00 ffff.ffff.ff00
  20 deny ip any mac 0000.0c9f.f000 ffff.ffff.f000
ip arp inspection filter HSRP_VMAC_ARP vlan [vlan-list]
/Ulrich
Correct Answer
bonestorm Tue, 10/23/2012 - 17:48
Hi Ulrich,
See this link:
Mark
Related Content
