Warning message
Tarik Admani Mon, 08/13/2012 - 08:50
  • Green, 3000 points or more
Kashish,
I do not think this feature is available in ISE, usually the traps that are sent for cold starts and warm starts..etc. However, I can not find any documentation regarding the snmp library for ISE management.
It would be best to get confirmation from TAC.
Tarik Admani
*Please rate helpful posts*
JAMES HILL Wed, 06/12/2013 - 09:40
You can do this within the ADE-OS command line of the appliances/VM.  Of course, the traps are relevant to the local device.
All of the standard SNMP commands are there.
erieddy Mon, 07/08/2013 - 08:36
  • Cisco Employee,
ISE supports a limited number of SNMP MIBs. They are documented here.
http://www.cisco.com/en/US/docs/security/ise/1.1/cli_ref_guide/ise_cli_app_a.html#wp1173352
You can send traps and poll ISE via SNMP. ISE does offers a robust set of alarms that can be configured that should provide what you are looking for.
http://www.cisco.com/en/US/docs/security/ise/1.1.1/user_guide/ise_mnt.html#wp1149284
You can configure alarms to send syslogs or email alerts but no SNMP traps. Think of ISE more like a server an less like a network switch. Most of my customers end up using alerts over SNMP.
muhammad.zeshan Sat, 11/16/2013 - 03:04
How to configure ISE to RECEIVE SNMP traps and how to see it on ISE console/GUI?
Related Content
