QOS on trunk interfaces
Aug 13th, 2012
When i configure subinterfaces on trunk interfaces which are located on Routers, What is the default packet queing rule for subinterfaces? Is there any configuration to make a subinterfcace has strick proirty than others?
Alessio Andreoli Mon, 08/13/2012 - 08:54
  • Silver, 250 points or more
Hi Muhammed,
if i have correctly understood your question you will possibly find useful these couple of answers:
a) the default for every interface is FIFO (first in first out) - as to say the firs to come is the first processed
b) you can define a subinterface with a stronger priority than others but this is not the purpose of QoS
find attached a very nice documentation about the commands you need to use to achieve your goals and specifically for your purpose i would like t sugest you to check the "match" command to fit the needs of your networks.
Take Care
Alessio
