08-13-2012 08:09 AM - edited 03-07-2019 08:19 AM
I have "inherited" a Catalyst 4506 with IOS version 12.2(20)EWA1 and Supervisor IV already installed. We recently purchased a second Supervisor IV and I am looking to install this second supervisor for redundancy. Is there anything special with installing a second supervisor or so I just physically install the new supervisor and the IOS will automatically set everything up? I've been searching and I can't really find any documents about how to do this. Thanks!
Solved! Go to Solution.
08-13-2012 08:22 AM
Hi!
You need have an identical IOS on both Supervisor (and identical hardware)
Supervisor engine redundancy is configured by default, but You can manually synchronized configuration as next:
Switch(config)# redundancy
Switch(config-red)# main-cpu
Switch(config-r-mc)# auto-sync standard
Switch(config-r-mc)# end
Switch# copy running-config startup-config
You can read more information on this doc
Helping seriously ill children, all together. All information about this, is posted on my blog
08-13-2012 10:49 AM
Dear ed ,
what is your switch model its 4506 or 4507 , if it 4506 it wont support for supervisor redudancy , because it has got only one supervisor slot , slot no 1
kindly look into below link for switch chasis comparison
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html#~two
Thks
santhosh sarav
08-13-2012 08:22 AM
Hi!
08-13-2012 10:49 AM
Dear ed ,
Thks
santhosh sarav
08-13-2012 12:37 PM
It's a 4506 chassis. Thanks for the information guys.
