Cisco VPN Client connected to 1841 router but not pinging to remote LAN
Aug 13th, 2012
Hi All,
Can anyone help me please...
I am trying to set up Remote access vpn in 1841 router. The vPN client is connecting to router, but cannot ping to remote LAN
Here is the config.
Current configuration : 3625 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable password mp**********14
aaa new-model
aaa authentication login AUTH local
aaa authorization network AUTH local
aaa session-id common
resource policy
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.107.200 192.168.107.250
ip dhcp excluded-address 192.168.107.24
ip dhcp pool mpo-dhcp
   network 192.168.107.0 255.255.255.0
   default-router 192.168.107.24
no ip domain lookup
ip name-server 4.2.2.6
ip name-server 4.2.2.5
ip ddns update method dyndns
HTTP
HTTP
    add http://username:[email protected]/nic/update?system=dyndns&h[email protected]/nic/update?system=dyndns&h
ostname=myip.dyndns.net&myip=<a>
interval maximum 0 0 1 0
vpdn enable
vpdn-group pppoe
username a***h privilege 15 password 0 ******************
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp client configuration address-pool lo
crypto isakmp client configuration group EZ
key m***********o7
dns 192.168.107.200 4.2.2.2
pool POOL
acl 101
netmask 255.255.255.0
crypto isakmp profile ISAKMP-P
   match identity group EZ
   client authentication list AUTH
   isakmp authorization list AUTH
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set TS esp-aes esp-sha-hmac
mode transport
crypto ipsec profile IP-MPO
set transform-set TS
set isakmp-profile ISAKMP-P
interface FastEthernet0/0
ip address 192.168.107.24 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
no ip address
speed auto
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface Virtual-Template1 type tunnel
no ip address
tunnel source FastEthernet0/1
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile IP-MPO
interface Dialer1
ip ddns update hostname mpo.dyndns.ws
ip ddns update dyndns
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname *********
ppp chap password 0 ************
ppp pap sent-username ********** password 0 ********
ip local pool POOL 10.0.0.10 10.0.0.15
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip dns server
ip nat inside source route-map VPN-NAT interface Dialer1 overload
access-list 101 permit ip 192.168.107.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 102 deny   ip 192.168.107.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 102 permit ip 192.168.107.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map VPN-NAT permit 10
match ip address 102
control-plane
line con 0
exec-timeout 0 0
line aux 0
exec-timeout 0 0
line vty 0 4
password **********
logging synchronous
scheduler allocate 20000 1000
end
I am not getting any hit on the deny statement of 102 when i try pinging to client ip address (10.0.0.10). Please check this and help with a solution.
mvsheik123 Thu, 08/16/2012 - 20:42
  • Gold, 750 points or more
Hi Shereef,
Config looks fine (unless I miss something). Internal sw/LAN device has route to 10.0.0.0/255.255.255.0 (or default route)points to router LAN ip?
Thx
MS
shereefmamballi Fri, 08/17/2012 - 03:50
Dear Sheik,
Thank you very much for your help. I was missing ip unnumbered command in
Virtual template interface, so ip services was disabled. Its working after the command.
Thank you again....
