Warning message
VXC 6215 .ini files examples
Answered Question
Aug 13th, 2012
Hi guys,
Does anyone has some examples of .ini configuration files?. I'm trying to push some configuration to a  VXC 6215 via VXCM.
Also i need to override some old configurations that the thin client already has, is it possible?
Christian Paz
Correct Answer by Jaime Valencia about 5 years 5 days ago
Reboot the client, and while it's booting, keep the G key pressed. You should see a green Cisco login screen
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 08/13/2012 - 17:37
  • Cisco Employee,
  • Hall of Fame,
    2011
Cisco Virtualization Experience Client   configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/vxc/english/vxc_6215_1-0/deploy/b_6215_fw8.6_deployment_guide_chapter_01_ps11976_TSD_Products_Installation_Guide_Chapter.html
As for the parameters:
Cisco Virtualization Experience Client 6215 INI Files  Reference Guide
http://www.cisco.com/en/US/docs/voice_ip_comm/vxc/english/vxc_6215_1-0/iniref/6215iniref.html
Once the client receives the new configs via a ini file the settings change accordingly, bear in mind that removing or not changing the same settings from the .ini file does not remove the old configurations unless you have preserve changes = no
ie
you had timezone in the .ini file with some value, if you remove the value from the .ini file, whatever you had before remains in the client config. Again, that unless you have preserve changes = no which basically means the client will get the config every single time it boots.
java
ChristianPaz Tue, 08/14/2012 - 13:33
Hi, do you know any procedure to go back to factory defaults (a hardware procedure), because i've been changing some parameters in the .ini files and now i can't access to the virtual desktops.
In vmware view the probles is that i can't use the mouse on the virtual desktop.
In citrix the browser crashes before displaying the desktop.
Correct Answer
Jaime Valencia Tue, 08/14/2012 - 17:03
  • Cisco Employee,
  • Hall of Fame,
    2011
java
