Warning message
Power Redundancy problem for cisco 3750 stack switches
Aug 13th, 2012
Hi Team,
I have installed and configured cisco 3750X series switches in stackwise. Those are having dual power supply.
Power redundancy test performed:
1. Removed one of the power supply and inserted it back.
2. once the first power supply is ready, removed another power supply and switch got rebooted.
please find the below stack-power output:
JP2-RDC-DIS-02#sh stack-power detail
Power Stack           Stack   Stack    Total   Rsvd    Alloc   Unused  Num  Num
Name                  Mode    Topolgy  Pwr(W)  Pwr(W)  Pwr(W)  Pwr(W)  SW   PS
Powerstack-2          SP-PS   Stndaln  700     477     223     0       1    2
Powerstack-1          SP-PS   Stndaln  700     477     223     0       1    2
Power stack name: Powerstack-2
    Stack mode: Power sharing
    Stack topology: Standalone
    Switch 2:
        Power budget: 223
        Power allocated: 223
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Port 1 status: Not connected
        Port 2 status: Not connected
        Neighbor on port 1: 0000.0000.0000
        Neighbor on port 2: 0000.0000.0000
Power stack name: Powerstack-1
    Switch 1:
        Power budget: 223
Can anyone help what went wrong here?
Manish
Leo Laohoo Mon, 08/13/2012 - 23:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Never tried this before but this could be it.
manish_3191 Tue, 08/14/2012 - 00:24
I have checked the other stack where power redundancy is working fine and it has stack topology:standalone only. But it has stack mode: Power Sharing strict thats the difference.
Really Wierd!!!
ptierce Mon, 11/05/2012 - 07:43
I had the same thing happen when installing a new stack.  One of the switches went into "Standalone" mode.  All you have to do to get it back into the powerstack is do the following:
conf t
stack-power switch x
  no standalone
end
Remember you'll have to manually assign all of the switches in the stack to a Powerstack because the default that it does to a large stack (> 4) isn't what you'll probably want.... as you saw.
John Capobianco Wed, 02/19/2014 - 07:26
Cosmetic bug
CSCui21029    3750X Stack no standalone stays in running configureation as standalone
Symptom:
When you are configuring a 3750x stack and initially putting it into a stack ring topology by configuring the following.
Switch(config)#stack-power switch 1
Switch(config-switch-stackpower)#sta
Switch(config-switch-stackpower)#no stan
Switch(config-switch-stackpower)#no standalone
You will see that in the running configuration it shows up as standalone mode
switch mode: standalone
stack-power switch 2
Conditions:
3750X stacks with any license level
Workaround:
none
