8.4 SNAT from Outside
Aug 14th, 2012
Could anyone tell me why this statement does not work? (No real IPs useD) DMZ Interface is 10.0.0.1/24
nat (outside,dmz) source dynamic any  interface destination static OBJECT-01 OBJECT-01
object network OBJECT-01
host 10.0.0.2
nat (dmz,outside) static 1.1.1.1 dns
Also tested:
nat (outside,dmz) source dynamic any  interface destination static OBJECT-01-out OBJECT-01-in
object network OBJECT-01-out
host 1.1.1.1
host 10.0.0.2
It works fine as following:
nat (outside,dmz) source dynamic any PAT-DMZ destination static OBJECT-01-out OBJECT-01-in
host 10.0.0.254
host 1.1.1.1
host 10.0.0.2
Thank you
Julio Carvajal Sat, 08/18/2012 - 23:41
1-Can you share the PAT-DMZ host
2- Why are you performing 2 different nats for the same purpose, I mean you are already letting the ASA now that if any outside users on the outside contact this ASA for the Ip address of Object-01 (1.1.1.1) the destination should be untranslated to 10.0.0.2 and the source should be translated to the PAT-DMZ ip.
So from my point of view you only need this:
With that line you are translating both the source and destination on one single line,
Let me know If I understood the question properly
Julio
