Warning message
Autonomous access point
Aug 14th, 2012
Can someone help me urgently
AP(it's 1130AG) is not pinging from access switch even it's formed neigbhourship
when i issued the command "Sh cdp nei" it's showing on my access switch but not pining from switch
i checked vlan and ports status everything is fine.
please helpme urgently
im on production......
John Blakley Tue, 08/14/2012 - 11:26
  • Purple, 4500 points or more
Can you post the config of the AP? Has it ever worked or is this a new install?
John Blakley Tue, 08/14/2012 - 12:12
We can't help you if you don't tell us addressing information, configurations, etc...CDP is a l2 protocol which only tells us that that part is working. Other than that everything would be purely a guess. Again, can you post the config of the AP?
Ven Taylor Tue, 08/14/2012 - 12:20
  • Bronze, 100 points or more
Can you ping the AP from anywhere else?
What is the switch port config for the AP?
Is this a good vlan with dhcp or does that AP have a static IP?
Ven
Alessio Andreoli Tue, 08/14/2012 - 12:50
  • Silver, 250 points or more
Try to issue
show cdp nei detail
share this info and the trunk config (uplink)
Alessio
Sivakanth Akkapu Tue, 08/14/2012 - 13:02
Hi All,
issue has been resolved
we forgot  the comman "default-gateway" in AP..now it's working
thank you all for quick response
Ven Taylor Tue, 08/14/2012 - 13:04
It's always the little things...
Related Content
