Compatibility Cisco Agent/Supervisor Desktop and Contact Center Express
Answered Question
Aug 14th, 2012
Hello
I am migrating all  the PCs to Windows 7 Professional, also i have an infrastructure of Contact Center Express in version 7.0(1) SR5 with Agents using the version of Cisco Agent Desktop 6.6.1.400. Once PCs migrated to Windows 7 Professional and installed with the Cisco Agent Desktop 6.6.1.400, we started having problems, the Cisco Agent Desktop agent appears and disappears from the Cisco Supervisor Desktop.  Intermittently Agent begins to disappear and appear on the Supervisor Desktop.
How can i fix this issue???...should i migrate the CAD to version 7.0.2 for supporting windows 7???..is CAD 7.0.2 supported by UCCX 7.0(1) SR5??
I would appreciate any help.
Alexis
Correct Answer by Chris Deren about 5 years 3 days ago
UCCX 7.0(1) SR5 supports CAD 6.6.1.400
You need to go to CCX 7.0.2 for CAD 7.0.2 which is the first version that supports Windows 7
per comptaibility doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 08/14/2012 - 13:19
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
alemunmo81 Tue, 08/14/2012 - 14:35
Thanks indeed Chris for you soon answer.
I will check the link for more details.
Alexis
Related Content
