AAA authentication / Radius-Servers
Aug 14th, 2012
                   Hello cisco folks,
Have a technical question I would like to ask. I'm able to setup my 3750e switch to login through a radius server with my company user id and password but would like to be able to set it up that when I log in it drops me on the enable prompt. Right now I have to type >en.
Then the enable password.  Thanks in advance.
Paul
Ramraj Sivagnan... Wed, 08/22/2012 - 23:59
  • Silver, 250 points or more
Hi Bro
Yes, this can be achieved in Cisco IOS devices but not in Cisco ASA. In Cisco ASA, you still have to type the "enable" command.
Just ensure you've the configuration shown below, and all should be good;
enable password cisco
aaa new-model
aaa authentication login VTY group radius local
aaa authentication login CONSOLE local
aaa authentication enable default group radius enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec VTY group radius local
username ram privilege 15 password 0 cisco
username cisco privilege 7 password 0 cisco
interface FastEthernet0/0
ip address 10.0.0.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip radius source-interface FastEthernet0/0
radius-server host 10.0.0.100 auth-port 1645 acct-port 1646 key cisco
privilege interface level 7 shutdown
privilege interface level 7 ip address
privilege interface level 7 no shutdown
privilege interface level 7 no ip address
privilege configure level 7 interface
privilege configure level 7 shutdown
privilege configure level 7 ip
privilege configure level 7 no interface
privilege configure level 7 no shutdown
privilege configure level 7 no ip
privilege configure level 0 no
privilege exec level 7 configure terminal
privilege exec level 7 undebug ip rip
privilege exec level 7 undebug all
privilege exec level 7 debug ip rip
privilege exec level 7 debug all
line con 0
login authentication VTY
line aux 0
line vty 0 4
end
Note: Ensure your user ID in your Radius server has the correct av-pair parameters shell:priv-lvl=15
P/S: if you think this comment is helpful, please do rate it nicely :-)
Related Content
