Warning message
Enabling port security on C4507R shuts down port
Answered Question
I'm trying to enable port security on several 4507R's. When I try to configure a range of ports the switch will randomly put 1 or 2 in err-disable.  It's different every time I apply the config to the same group of ports.  However if I do them one at a time it seems to work.  But I really don't want to configure 6 fully populated switches one port at a time.   We also have a lot of 3750's and they gave me no problem using a port range.
Here is the config I'm trying to configure
switchport port-security
switchport port-security maximum 2
switchport port-security aging time 1
switchport port-security aging type inactivity
The IOS version is. 12.2(25)EWA8
Correct Answer by Benjamin Kools about 5 years 5 days ago
Try rearranging the order in which you put the commands in. Put "switchport port-security" in last, as immediately when you enter this command, port security is enabled with the default maximum of 1 mac address per interface. If a port has two hosts on it before the next command setting the maximum to 2 is entered, it will get disabled.
Another option is to temporarily enable error disable recovery:
errdisable recovery cause psecure-violation
errdisbale recovery interval 'seconds'
Overall Rating: 5 (1 ratings)
Correct Answer
Benjamin Kools Tue, 08/14/2012 - 17:58
johnlloyd_13 Wed, 08/15/2012 - 07:38
  • Blue, 1500 points or more
Make sure the ports you're trying to configure are access ports (switchport mode access).
Related Content
