Warning message
Monitoring Service not running
Aug 16th, 2012
Hi there,
I don't know if this a feature or works as designed or a bug, but when connecting to my Onplus directly, the status page says: "Monitoring - not running" (sorry, its a german device and I don't have the translation available. Startpage - last entry "Überwachung: Wird nicht ausgeführt"
When I try to connect to a server I find the event:
Process ended unexpected - monitor not running.
Any idea what I can do? Restarting does not change anything.
kind regards
eckhard
aqkazi Fri, 08/17/2012 - 08:21
  • Bronze, 100 points or more
Hi Eckhard,
I was taking a look through your sites and it seems you have 2 On100s at the same site as both have the same WAN IP. Could you help me understand as to why you have it configured like this? This could be the cause of the monitoring issue.
The OnPlus Team
Eckhard Eilers Fri, 08/17/2012 - 09:40
Hi Onplus Team,
thanks for your quick support. Yes, there are two agents. the second one (*AGENT2) was installed to find out if the problem with the first agent were due to local network problems, firewall limitations and so on. this is not the case. The second agent is working as expected (monitor service is running), the first one is not.
Hope this helps.
Kind regards, and again, thanks for your support
eckhard
aqkazi Fri, 08/17/2012 - 09:46
Thanks Eckhard.
Do you happen to have a screenshot of the 'monitoring' message that appears? I want to be sure I'm understanding where this message comes up correctly.
Also, does this appear on the 1st or 2nd On100 at this site?
The OnPlus Team
aqkazi Fri, 08/17/2012 - 12:49
Hi Eckhard,
I would like to pull support logs from this On100, I just need your authorization before pulling them. Please let me know if you approve.
The OnPlus Team
aqkazi Fri, 08/17/2012 - 13:07
Thanks Eckhard. I've collected the logs and sent them to our Engineering team for review.
Thanks again,
The OnPlus Team
Eckhard Eilers Mon, 08/20/2012 - 07:59
hi there OnPlus team,
we resetted the onplus box today to factory defaults and now the service is running.
sorry, if I intercept your research, but it was important that the box is up again.
so, thanks for you help, I hope the logs will give some insights.
best regards
eckhard
Michael Holloway Mon, 08/20/2012 - 08:34
  • Cisco Employee,
Hi Eckhard,
Aqib retrieved your ON100 support log files and we're trying to recreate the issue on our now end. Thanks for providing access to them, they should help us to get to the bottom of the issue and hopefully prevent it from occurring in the future. I'm happy to hear that a factory-reset got you working again.
-mike
