Warning message
VPN Problems ASA 5505 to 7206 Router MM_WAIT_MSG2
Aug 16th, 2012
Since I swapped a Pix Firewall for a Cisco ASA 5505 Firewall at one of our Sites the VPN Tunnel wont come up
I'm getting this:
asaXXXXX# sho crypto isakmp sa
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 10.150.242.23
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG2
asaXXXXX#
below is the crypto relevant settings off the ASA:
access-list outside_cryptomap_10 extended permit ip object-group Net_Inside any
access-list outside extended permit ip object-group Network_PPCUK any log debugging
access-list outside extended permit icmp any any
access-list outside extended permit ip object-group Network_QSec any log debugging
access-list inside extended permit ip object-group Net_Inside any
access-list inside extended permit icmp any any
access-list inside_nat0_outbound extended permit ip 10.xxx.xxx.x 255.255.255.192 any
access-list outside_1_cryptomap extended permit ip 10.xxx.xxx.x 255.255.255.192 any
access-list vpn extended permit ip object-group Net_Inside any
access-list outside_cryptomap_11 extended permit ip 10.xxx.xxx.x 255.255.255.192 any
crypto ipsec transform-set vue2 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 14400
crypto ipsec security-association lifetime kilobytes 4608000
crypto map site-crypto-map 10 match address outside_cryptomap_11
crypto map site-crypto-map 10 set pfs
crypto map site-crypto-map 10 set peer 10.150.242.23
crypto map site-crypto-map 10 set transform-set ESP-3DES-SHA
crypto map site-crypto-map 10 set security-association lifetime seconds 14400
crypto map site-crypto-map 10 set security-association lifetime kilobytes 209715
crypto map site-crypto-map 10 set trustpoint ukpvca
crypto map site-crypto-map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication rsa-sig
encryption 3des
hash sha
group 2
lifetime 14400
crypto isakmp policy 65535
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp am-disable
below is the crypto map settings off the 7206 Head End Router:
encr 3des
group 2
lifetime 14400
crypto isakmp identity hostname
crypto isakmp keepalive 30 3
crypto ipsec security-association lifetime kilobytes 2097152
crypto ipsec transform-set xxx ah-sha-hmac esp-3des esp-sha-hmac
crypto ipsec transform-set xxxx esp-3des esp-sha-hmac
crypto map vue 2148 ipsec-isakmp
set peer 10.155.248.82
set transform-set vue2
set pfs group2
match address SITENAME
This 7206 Router has 140 VPN Tunnels running on it and the rest are all ok only this one Site thats not working
Any feedback would be much appreciated!
CLIGuru
Jouni Forss Thu, 08/16/2012 - 05:38
I guess this usually means that the remote end doesnt reply to the initial message from initiator of the connection which in this case is the new ASA5505. Is there perhaps some errors in the new ASA configuration or with its routing?
- Jouni
Paul Hathaway Thu, 08/16/2012 - 06:30
I've compared the configs to a known working ASA and theylook identical
I ran a debug crypto isakmp  251 and got the following:
Aug 16 14:29:11 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:11 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:11 [IKEv1]: IP = 10.150.242.23, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 168
Aug 16 14:29:12 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:12 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:13 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:13 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:14 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:14 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:15 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:15 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:37 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:37 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:38 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:38 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Aug 16 14:29:39 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Aug 16 14:29:39 [IKEv1]: IP = 10.150.242.23, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Strange eh ?!
Jouni Forss Thu, 08/16/2012 - 06:36
Btw,
Why doesnt the router side policy have anykind of "authentication" under the isakmp policy ?
Paul Hathaway Thu, 08/16/2012 - 09:16
Good question Im not sure its never had authentication before and we have another Head End Router that performs the same function and that has the same settings
its a really bizzare issue al lthe configs look right at both ends but the tunnel seems to be stuck possibly traffic being blocked?!
Paul Hathaway Fri, 08/17/2012 - 04:34
Think I'm getting somehwere :
asaSITEName# packet-tracer input inside tcp 10.155.148.3 500 10.150.242.23 5$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
static (inside,outside) 10.155.148.0 10.155.148.0 netmask 255.255.255.192
  match ip inside 10.155.148.0 255.255.255.192 outside any
    static translation to 10.155.148.0
    translate_hits = 3516, untranslate_hits = 0
Static translate 10.155.148.0/0 to 10.155.148.0/0 using netmask 255.255.255.192
Phase: 6
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 7
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: VPN
Subtype: encrypt
Result: DROP
Config:
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Traffic is being dropped at the encryption level question is is it at the ASA Side or the VPN Router ??
