Multiple NAT's For Range Within 1 Subnet
Aug 16th, 2012
Sorry for the title, maybe a litte confusing. I wasn't sure how to title it.
Thanks for taking the time to read this.
Basically I need to create a few external ip address which translate to multiple range within our subnet.
192.168.10.1 is our subnet
I would like to have say
192.168.10.10 - 50 <----- 82.48.68.84
192.168.10.51 - 71 <----- 82.48.68.85
192.168.10.72 - 100 <------ 82.48.68.86
Is this possible using the ip nat commands?
Any ideas,
Thanks again,
BigDawgFelton Thu, 08/16/2012 - 18:20
I think I had a config like that where I had multiple outside interfaces and then just used my NAT statements to tell the router which IP to translate to.
As I have learned more about Cisco my first thought is now to use route maps. I think this gives you more control of where your traffic is going for each set of IP addresses.
