ISE Authorization Compound Condition
Aug 16th, 2012
I am trying to add a compound condition that points to an internal identity group in an authoirization profile. Something like the rule below.However the rule never gets applied for users in the IT identity group. It moves to the next rule down and applies permissions based off another rule specific for just the device type. If I change the rule conditions to use the identity group instead of the device type it works. However, I want to limit the rule to device type and Identity group. Any ideas would be appreciated.
Rule Name: test       Conditions: Android and IT (Expression: InternalUser:IdentityGroup EQUALS IT) then PermitAccess
Venkatesh Attuluri Sat, 05/11/2013 - 04:28
  • Cisco Employee,
try creating device groups and match them
Network Device Groups List > New Network Device Type
* Name
Description
* Type
Authentication RulesEnabled
Name
Condition
Protocols
Identity Source
Options
TestAuthentications
IF
Device:Device Type = Device   Type#All Device Types#Test
allowprotocols
DefaultNetworkAccess
and use
demo.local
RejectRejectDrop
MAB
IF
Wired_MAB
allowprotocols
and use
InternalEndpoints
RejectRejectDrop
Dot1X
IF
Wired_802_1X
allowprotocols
and use
AD_InternalUsers
RejectRejectDrop
Default Rule(if no match)
allowprotocols
and use
Internal Users
RejectRejectDrop
Related Content
