Warning message
UCCX 7.x to 8.5x upgrade pre-planning
Aug 16th, 2012
I have bits and pieces of thing to check prior to upgrading uccx from version  7.x to 8.5x.  Is there a document out there that contains a complete list of  things that have changed in the configuration or things to check prior to  upgrade and migrating the data.
I am thinkings of a list such as:
- Enterpise data settings will not migrate
- work flow settings will not migrate.
- database settings will need to be converted.
- scripts that write and read xml files need to checked.
- icd must appear on lines 1-4 only.
And direction would be helpful.
Chris Deren Thu, 08/16/2012 - 17:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Have you read the install/upgrade guide and release notes?
Chris
Related Content
