DOES WLC-2504 SUPPORT AIR-LAP1262N-A-K9 AND AIR-CAP3602E-A-K9
Answered Question
Aug 16th, 2012
HI:
We´re using a WLC 2504 and currently instaled AIR-LAP1252AG-A-K9, but we want to install some AP´s both 1262 and 3602, I just want to confirm that this controller really support this new AccessPoint.
Could you please confirm this issue and if neccesary upgrade version on the controller what version should we use.
Ellen Macias
Correct Answer by Stephen Rodriguez about 5 years 1 day ago
Yes both AP are supported on the 2504.
As for the upgrade procedure take a look at the release notes. It documents the process pretty well.
Steve
Overall Rating: 5 (1 ratings)
Stephen Rodriguez Thu, 08/16/2012 - 15:57
  • Purple, 4500 points or more
To support both AP you would want to upgrade to the 7.2 train of code. Of recommend that you go with the latest version.
Steve
jluis.macias Thu, 08/16/2012 - 16:09
STEVE:
It means that both AP are supported by the 2504 WLC?
Something else, could you reply to me information about the upgrading process.
Thanks very much
Ellen
Correct Answer
Stephen Rodriguez Thu, 08/16/2012 - 16:23
Steve
Leo Laohoo Thu, 08/16/2012 - 16:08
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
As what Steve said, the 3600 is supported in firmware 7.2.103.0.  The 1260 is supported in earlier firmware.
I also agree that it's better if you use the newer firmware, 7.2.110.0.
Please be aware that the 2504 maybe able to support the 3600 but understand that if you are using 802.11n then the 2504 will severely not be able to cope with the load.
This will get even worst when the 802.11uc add-on module will be released this year.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
