XML BLF (via Provisioning File)
joaomigsilva
Hello!
I'm developing the provisioning via XML code and the BLF configs is not working right.
I'm not using a Broadsoft server and I'm testing the following code into the complete provisioning file:
<!-- Line Key 3 -->
<Extension_3_ ua="na">Disable</Extension_3_> <!-- options: 1/2/3/4/5/Disabled -->
<Short_Name_3_ ua="na"></Short_Name_3_>
<Share_Call_Appearance_3_ ua="na">private</Share_Call_Appearance_3_> <!-- options: private/shared -->
<Extended_Function_3_ ua="na">fnc=blf+cp;sub=+351211959651@DOMAIN;ext=+351211959651@DOMAIN</Extended_Function_3_>
I made this following the example on ADMIN GUIDE, can you help me ?
Thanks in advance
0 Replies 0
