Warning message
ashirkar Thu, 08/16/2012 - 23:14
  • Gold, 750 points or more
Cisco devices use the syslog to manage system logs and alerts. But in Cisco devices there is lack of large internal storage space for storing these kinds of logs.So to overcome Cisco devices has the following two options:
1) internanal buffer That is a small part of memory buffers to collect log the most recent messages. The buffer size is limited and , when the device reboots, these syslog messages are lost.by default it is on
(If not follow this steps
conf t
logging on
logging console.....console logs
logging buffer  size ......set the size of buffer
terminal monitor.......to gets logs on the remote terminal like telnet,ssh etc.
sh logging.........to see buffer logs.)
2) Syslog server—  By using this we can send messages to an external device for storing this logs and the storage size does depend on the available disk space of the external syslog server. This option is not enabled by default.
If you have any syslog server please find the below simple config .
conf t
logging host x.x.x.x
logging traps (i.e 0 1 2 3 4 5 .. according to your requirement)
before enabling logging be sure that your router is properly configure to collect proper time from any NTP server or manually configure to get time
command to set time manually on router is (set clock ) or to use ntp server use ntp server x.x.x.x to sync clock to router router.
Hop thant is informative ,
Ashish
Marvin Rhoads Sat, 08/18/2012 - 12:03
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Adding to Ashish's informative reply, I generally set logging buffer size to 50000 in order to get a good size log saved in memory. The default size (4k) doesn't give one may log events stored in memory.
