Cisco CDA and Windows-Firewall
Aug 17th, 2012
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
I just wanted to migrate from the AD-Agent to the CDA but I'm running into some problems with the windows firewall. That's the situation:
- The AD_Agent was running fine (with Windows-Firewall on DC enabled).
- The CDA can connect to my DC when I disable the Windows-Firewall
- The CDA can not communicate to my DC when I enable the Windows-Firewall. The error is:
org.jinterop.dcom.core.JIComServer.init(JIComServer.java:576)
org.jinterop.dcom.core.JIComServer.initialise(JIComServer.java:481)
org.jinterop.dcom.core.JIComServer.(JIComServer.java:414)
com.cisco.cda.rt.adobserver.adobserver.jinteropUtil.getWmiLocator(jinteropUtil.java:39)
com.cisco.cda.rt.adobserver.adobserver.EventsThread.connectToDomainController(EventsThread.java:545)
com.cisco.cda.rt.adobserver.adobserver.EventsThread.run(EventsThread.java:613)
exception-text
An internal error occurred. [0x8001FFFF]
server
dc-hostname
10.255.192.159
connection-type
com.cisco.cda.rt.adobserver.adobserver.CurrentEventsThread
- I use the same user-account I used for the AD_Agent. The permissions for the two registry-keys that are stated in the install-guide are set.
- The rule for "Windows Management Instrumentation (WMI)" in Windows-Firewall is activated.
- The DC is running a german Windows 2008 R2. In the CDA-documentation I didn't find any hint that a localized Windows is unsupported, so I hpre that this is not the problem.
Any hints what I could be missing?
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
eshabat Tue, 08/21/2012 - 01:09
Hi Karsten,
Localized versions are supported, so that is probably not the issue here.
You can create a custom rule in the Windows firewall to allow udp and tcp traffic from the CDA and see if it solves your problem.
Erez
mvassigh Tue, 03/05/2013 - 10:04
  • Cisco Employee,
Hello Karsten, Erez,
I have noticed the same issue and error message. The only quick-fix was a FW-Policy allowing CDA-TCP connectivity to Windows-AD.
This is somehow strange, as I followed the latest CDA-Patch documents and did insert the WMI-Firewall-Access policy already, but this was not enough though.
To me it looks like some RPC/DCOM mapping is not opened for CDA to access the AD-Server.
regards
/michael
s.fasel Mon, 11/25/2013 - 22:45
Hello Michael,
I also have noticed the same issue.
Your solution that create a FW rule to open all TCP ports between CDA and Windows-AD works fine.
But is there no another solution (more securely) ?
Thanks for your response
Best regards
Sam
Related Content
