Warning message
Block P2P traffic on Cisco 5508 Controller
Aug 17th, 2012
Is it possible to block outside P2P traffic on a guest wireless network using an ACL on the controller?  I know we can do it our firewall but the question came up so I thought I would post and see what everyone thinks.  TIA
Overall Rating: 5 (2 ratings)
Dirk Woellhaf Fri, 08/17/2012 - 07:00
What you can do is, to block P2P traffic inside a SSID.
Can be configured on a per-SSID basis.
regards,
    Dirk
skelley5000 Fri, 08/17/2012 - 07:01
I believe on the WLC under the WLAN you are referring to, click on the Advance tab and there is a P2P blocking action. I believe that will help you out with what you are wanting to do.
bm_5789 Fri, 08/17/2012 - 07:04
Thanks to all who replied.  I already restrict P2P for the SSID.  I was curious about blocking internet/outside P2P.
Again Thanks!
George Stefanick Fri, 08/17/2012 - 07:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Yes, ACLs can be applied to the WLC. I might suggest moving the ACL to the closest point, the FW if you are concern about internet traffic.
ACLs on Wireless LAN Controllers: Rules, Limitations, and Examples
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00807ce372.shtml
bm_5789 Fri, 08/17/2012 - 07:19
Thanks for all the info and the link.  It is very helpful.
George Stefanick Fri, 08/17/2012 - 10:39
No problem. Stop back if you have any other issues or questions.
Related Content
Trending Topics - Security & Network
