Secondary ISE cannot join the primary node with error message
Answered Question
Aug 17th, 2012
I have just installed the secondary ISE and did the followings, but when I try to join the primary node, I received the Cannot authenticate the primary ISE, please check the server or certificate and try again.
- promote the secondary from standalone to primary
- export self cert from the seconary
- import the cert to the primary
- try to add not on the secondary used both IP and host name with super admin user
One thing I have noticed that the instruction on the ISE 1.1.1 import cert on primary section mentioned:
  1. Choose Administration > System > Certificates.
  2. From the Certificate Operations navigation pane on the left, click Certificate Authority Certificates.
but the Certificat Authority Certificates does not exist on the left pane. I choosed Certificate store instead
any suggestions?
Correct Answer by Tarik Admani about 4 years 7 months ago
Did you set the secondary node to primary? You may have tried to register the node in the wrong direction. For a node to register with the primary node, the registration request must be initiated from the primary node.
Tarik Admani
*Please rate helpful posts*
Overall Rating: 5 (1 ratings)
edondurguti Fri, 08/17/2012 - 08:37
I've seen that order to be different on the cert guide aswell.
Make sure that the admin password matches
Mountain Man Fri, 08/17/2012 - 08:39
Yes. Admin password is match. I have also tested to using a different super admin user created on both system. none of them working
edondurguti Fri, 08/17/2012 - 08:41
do you have both certs on the primary node as of right now?
if you go to
choose Certificate Store
what do you see there?
Mountain Man Fri, 08/17/2012 - 08:44
Yes. I have two certs there, one is local/primary the other one is imported from the secondary
Mountain Man Fri, 08/17/2012 - 08:54
I tried to add the cert from primary and imported it into the secondary. Run add note again, get different error:
Unable to register primary_host. Node is not a Standalone node.
Correct Answer
Tarik Admani Fri, 08/17/2012 - 08:58
  • Green, 3000 points or more
Tarik Admani
Related Content
