Warning message
ACS v. 5.1 Authentication methods
Aug 17th, 2012
I hope my question has not been yet asked. But it's so complicated to explain that I don't even know on which keywords to search.
I'd like to define 2 types of users on my ACS:
1- Users who use basic authentication with a password
2- Users who use an external token server.
The issue is that I don't manage to make both work together:
I've created 2 service selection rules and depending on how I order them, the token user can authenticate but not the fix password one and vice versa.
Does someone either have an idea or a clear documentation about how to configure this simple feature on the ACS?
In version 4, this was really easy: 1 group with ext authentication, and one with local DB password.
In version 5, I do not find how to do it.
Thanks a lot!
Patrick
Tarik Admani Fri, 08/17/2012 - 08:55
  • Green, 3000 points or more
Patrick,
Are the usernames present in both databases? If not,you can create an identity store sequence ( it will check AD then RSA) but you can set the sequence in any order you like:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/users_id_stores.html#wp1054132
Tarik Admani
*Please rate helpful posts*
Related Content
