Warning message
ASA VPN Tunnels with Certificates
Aug 17th, 2012
Hi there,
I'm newbie in the CISCO supportforum and have a question about VPN Tunnels between ASA's.
My ASA's have the follwing Versions: ASA Version 8.4(3) ASDM Version 6.4(7)
Have I a chance  to configure a site-to-site tunnel with a hostname as peer address when I will use Identity and CA Certificates?
Is there a How-To or more  information in the supportforum?
Many Thanks for replies
Rainer Bolsinger
Karsten Iwen Fri, 08/24/2012 - 00:58
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
If you want to use FQDNs because both your ASAs have dynamic IP-addresses, then the answer is no. At least one ASA needs to have a fixed IP. And then it doest't matter if you use PSK or certificate-authentication. But the IPSec peer always has to be specified by the IP-address.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
