qsic trunk
Aug 17th, 2012
  i am trying to  configuredqsic trunk between cme and panasonic pbx.but the controller is down.here is the show command.
cme#show controllers e1
E1 0/2/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (649 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 649 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
what could be the reason?
thanks
kavi
Leo Laohoo Sat, 08/18/2012 - 00:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Duplicate post #1.
Chris Deren Sat, 08/18/2012 - 01:36
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
Try different cable and crossover.
Amim Ansari Sat, 08/18/2012 - 04:31
make CME trunk as master and panasonic as salve , waht you are using here , can you paste show isdn st here . here it alos shows loss of signal , check yr cabling aprt too
rgds
Amim
if this helps, please rate
Amim Ansari Sat, 08/18/2012 - 04:33
hi,
and make sure you use all 30 channel of E1 ,as sometime it does not worked with fragmneted channel .
rgds
AMim
