urgent help !! problem when ASA connect site-to-site with pix
yiuyuenyan
Hello, I've a question about Cisco ASA, last week I try to use ASA connect to pix but fail
local Site using ASA with static ip
the ASA is already acts as a remote access vpn server which accept outside peoples through ipsec connect local lan already
remote Site using pix with dynamic ip
is there any command line missing in the site-to-site configuration with pix & asa ?
here is the config file in ASA & Pix also, anyone can give some sugguestion is appreciate !
ASA:
ASA Version 8.3(1)
hostname ciscoasa
domain-name default.domain.invalid
enable password 3Wyb.JCq2csepdi encrypted
passwd 8KCQnbNPcI.6KROM encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group PCCW
ip address pppoe
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone HKST 8
dns server-group DefaultDNS
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network rdp_3389
host 192.168.1.200
object network NETWORK_OBJ_192.168.1.0_24
subnet 192.168.1.0 255.255.255.0
object network NETWORK_OBJ_192.168.20.0_27
subnet 192.168.20.0 255.255.255.224
object network Main-Office
object network Branch-Office
subnet 192.168.33.0 255.255.255.0
object network Site-A-Subnet
object network Site-B-Subnet
object network Site-B-firewall
host 183.178.xx.xx
access-list OUTSIDE-IN extended permit tcp any host 192.168.1.200 eq 3389
access-list OUTSIDE-IN extended permit icmp any any echo-reply
access-list OUTSIDE-IN extended permit icmp any any source-quench
access-list OUTSIDE-IN extended permit icmp any any unreachable
access-list OUTSIDE-IN extended permit icmp any any time-exceeded
access-list VPNGROUP_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 obj
ect Site-B-Subnet
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool addresspool 192.168.20.10-192.168.20.30 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static NETWORK_OBJ_192.168.20.0_27 NETWORK_OBJ_192.168.20.0_27
nat (inside,outside) source static Main-Office Main-Office destination static Branch-Office Branch-Office
nat (inside,outside) source static Site-A-Subnet Site-A-Subnet destination static Site-B-Subnet Site-B-Subnet
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static Site-B-Subnet Site-B-Subnet
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp 3389 3389
access-group OUTSIDE-IN in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.20.0 255.255.255.0 inside
http 119.247.xx.xx 255.255.255.252 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128
-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256
-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 183.178.xx.xx
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 600
crypto isakmp ipsec-over-tcp port 10000
telnet 192.168.1.0 255.255.255.0 inside
telnet 192.168.20.0 255.255.255.0 inside
telnet timeout 30
ssh 192.168.1.0 255.255.255.0 inside
ssh 192.168.20.0 255.255.255.0 inside
ssh 119.247.xx.xx 255.255.255.252 outside
ssh timeout 30
ssh version 2
console timeout 0
management-access inside
vpdn group PCCW request dialout pppoe
vpdn group PCCW localname maqaccount012
vpdn group PCCW ppp authentication pap
vpdn username mac1account1012@work password ******
dhcpd auto_config outside
dhcpd address 192.168.1.160-192.168.1.190 inside
dhcpd dns 203.198.23.208 218.102.32.208 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy VPNGROUP internal
group-policy VPNGROUP attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPNGROUP_splitTunnelAcl
username vpnclient password PekoINFEvjsdPsn encrypted privilege 0
username vpnclient attributes
vpn-group-policy VPNGROUP
tunnel-group VPNGROUP type remote-access
tunnel-group VPNGROUP general-attributes
address-pool addresspool
default-group-policy VPNGROUP
tunnel-group VPNGROUP ipsec-attributes
pre-shared-key *****
tunnel-group 183.178.xx.xx type ipsec-l2l
tunnel-group 183.178.xx.xx ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DD
CEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:50db8538c9b17e0fb49534de1a4ba935
: end
PIX:
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password VDcS/JTrc3R5UuT/ encrypted
passwd 1KDQndNdI.2IOH encrypted
hostname pix506e
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
name 192.168.1.0 Site-A-Subnet
access-list acl_out permit icmp any any echo-reply
access-list acl_out permit icmp any any source-quench
access-list acl_out permit icmp any any unreachable
access-list acl_out permit icmp any any time-exceeded
access-list acl_out permit tcp 119.247.xxx.xx 255.255.255.252 host 183.178.xxx.xxx eq ftp
access-list inside_outbound_nat0_acl permit ip 192.168.33.0 255.255.255.0 Site-A-Subnet 255.255.255.0
access-list outside_cryptomap_20 permit ip 192.168.33.0 255.255.255.0 Site-A-Subnet 255.255.255.0
pager lines 24
interface ethernet0 10full
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.33.150 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.33.100 255.255.255.255 inside
pdm location Site-A-Subnet 255.255.255.0 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp 183.178.xx.xx ftp 192.168.33.100 ftp netmask 255.255.255.255 0 0
access-group acl_out in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.33.0 255.255.255.0 inside
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set pfs group2
crypto map outside_map 20 set peer 218.103.118.xxx
crypto map outside_map 20 set transform-set ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-MD5 ESP-DES-SHA
isakmp key ******** address 218.103.xx.xx netmask 255.255.255.255 no-xauth no-config-mode
isakmp keepalive 3600 10
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet 192.168.33.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.33.0 255.255.255.0 inside
ssh timeout 5
dhcpd address 192.168.33.151-192.168.33.254 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
username pix506e password acgODpC4FIvCA9GD encrypted privilege 3
terminal width 80
Cryptochecksum:80af400964b431db9c1ab697c09a4beb
: end
Jennifer Halim
If PIX has dynamic IP, then only the PIX end should have static crypto map.
The following should be removed on the ASA end:
Also remove the following from the PIX end:
After the above, pls share where it's failing if it's still not working.
Share the output of :
show cry isa sa
show cry ipsec sa
