Warning message
Client VPN fails with ISAKMP errors
Answered Question
Aug 15th, 2012
situation:
cisco 878 configured to accept client vpn requests. From client prospective people get error 412 and they can't connect. Not sure what s wrong, following configuration and debug isakmp. Autentication is through a radius server.
thanks in advance.
Correct Answer by Marcin Latosiewicz about 5 years 5 days ago
In the config above - you have wrong crypto map assigned to interface.
Also, I'd suggest using VTI based setup and not crypto maps.
Overall Rating: 5 (1 ratings)
Correct Answer
Marcin Latosiewicz Thu, 08/16/2012 - 02:11
  • Cisco Employee,
ndazzi.rdac Thu, 08/16/2012 - 21:52
thanks for the tip
I have changed
crypto map VPNTOMEL 1 ipsec-isakmp
--More--                            description VPN to Perth
set peer $$$$4
set transform-set ESP-3DES-SHA
set pfs group2
match address 118
to (so it has the same name as the group vpn).
crypto map RDAPER 2 ipsec-isakmp
set peer $$$$4
set pfs group2
match address 118
changed the crypto map in the dialer interface to crypto map RDAPER
The IPSEC vpn went back up, but i m still getting the same errors connecting using the vpn client
any clues?
thanks
ndazzi.rdac Thu, 08/16/2012 - 22:26
i ve marked the answer as correct so you can get some rep back. Thanks for putting me in the right direction.
That was one problem the other problem that the crypto map was missing:
crypto map RDAPER 10 ipsec-isakmp dynamic dynmap
thanks
Nick
Related Content
