Warning message
1262 antenna direction
Aug 20th, 2012
  • Silver, 250 points or more
Dear all,
I have to replace a 1230 with an 1262 AP. Do you have any suggestions for me or I'm right with my ideas?
All antennas have to be in the same direction on the AP and I guess when the old 1230 is working well the 1262 will be only better .
Atteached u see how I plan to mount the new AP versus the old one...
I'm happy to hear from you.
regards,
Sebastian
Overall Rating: 3.3 (3 ratings)
Leo Laohoo Mon, 08/20/2012 - 02:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Make sure the antennas are pointing in the general direction of the client.
If the WAPs flushed on the ceilling then the antennas are pointed towards the floor.
George Stefanick Mon, 08/20/2012 - 18:06
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Some may disagree and I dont know if Im a fan of it either. However, I have seen and been part of conversations with other wireless engineers specific to 802.11n access point, antennas could benefit from placing the antennas in different directions.
Sebastian Helmer Mon, 08/20/2012 - 23:23
Hi George,
Thanks, I heard that too sometimes but I'm not sure.
I'll check it with a survey on site as soon as I get the chance.
Thank you all for your replies!
-Sebastian
Scott Fella Tue, 08/21/2012 - 03:55
  • Hall of Fame,
    2017 Wireless
Just to add my 2 cents.
Take a look at the antenna pattern from the Cisco antenna reference guide. If you want to cover more horizontal than vertical, then the dipole should be pointing up or down. If you want to cover more vertical, the the antennas should be at a horizontal position.
The middle port is a RX port, if you have that antenna position different from the outer antenna ports, it will most likely not be used because of the diversity algorithm.
George Stefanick Tue, 08/21/2012 - 06:25
Scott I would think the opposite would happen. As each frame is sensed by the AP and then only one antenna engages to accept that frame . Or at least this is my understanding. We could very well be splitting hairs ..
Amjad Abdullah Mon, 08/20/2012 - 18:01
  • Red, 2250 points or more
Make sure the antennas aren perpendicular to the ground.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
