Warning message
remote access vpn authorization using Cisco ACS 5.3 and ASA 8.2
Aug 20th, 2012
Hi all,
we plan to use ACS 5.3 for remote vpn user authorization.
we have found a document on to how to do this, but they use ASA 8.3.
we would like to know if it is supported on ASA 8.2 or do we need to upgrade the ASA IOS.
Overall Rating: 5 (1 ratings)
Marcin Latosiewicz Mon, 08/20/2012 - 13:26
  • Cisco Employee,
What specific features were you interested in. Typical RADIUS authorization process didn't change much between ASA 8.2 and 8.3 (and 8.4 for that matter).
You can compare here:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/access_aaa.html
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/access_aaa.html
Unless you were looking for somethign very specific?
harinirina Mon, 08/20/2012 - 22:40
yes,we plan to use RADIUS authorization.
Thanks a lot for your reply.
Related Content
