Warning message
wcs to ncs migration problem.
Aug 21st, 2012
                   Hi.
I have problem to migrate wcs ver 7.0.220.0 to ncs 1.1.1.24.
When i tried to migrate i get this error message:
s00ml600/admin# ncs migrate wcs-data wcs.zip repository ncs-ftp-repo
Initiating WCS 7x DB restore .  Please wait...
INFO: no staging url defined, using local space.        rval:2
Starting Network Control System...
This may take a few minutes...
Network Control System started successfully.
Stopping Network Control System...
Network Control System successfully shutdown.
  Stage 1 of 5: Decompressing backup ...
Failed to unzip backup file /opt/CSCOncs/migrate/restore/wcs.zip, Exception: Negative seek offset
s00ml600/admin#
Lasse
Scott Fella Tue, 08/21/2012 - 04:00
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Make sure the WCS.zip is not empty. Also, is the WCS.zip in the correct FTP path and what do you see on the FTP server when the NCS is trying to upload the file?
Issue a show repository and verify the WCS.zip shows up.
Amjad Abdullah Tue, 08/21/2012 - 13:23
  • Red, 2250 points or more
I think either the FTP server IP address, the path or the file name is not correct. Double check.
sem7433 Wed, 08/22/2012 - 03:34
It works find to get wcs.zip from ftp servern. It's when the wcs.zip be unpacket as it doesn't work. And i have check that wcs.zip is not empty. But i have no rights to look in /opt/....
Scott Fella Wed, 08/22/2012 - 03:54
  • Hall of Fame,
    2017 Wireless
You might want to run the WCS export again to an FTP repository then you should be able to look at the file.
Related Content
Trending Topics - Security & Network
