ATT CONSOLE 8X
Aug 21st, 2012
Hi Jaime,
question
Do I need 12 CUE-ATT-CON=  V8x licences + Server  in order to have 12 human console operators? or this
CUE-ATT-CON=  V8x  licence is for server?
My customer needs 12 people  at different sites receiving incomming calls.
I Would Appreciate your coments and help
Gonzalo C
Chris Deren Tue, 08/21/2012 - 17:15
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Correct, each CUE-ATT-CON= allows for one concurrent AC operator login.  Keep in mind that CUEAC server can support up to 25 operators concurrently logged in as long as you have SQL server installed, with SQL Express you can only scale up to 10, so you need to purchase SQL license as well.
HTH,
Chris
Christian Bongi... Wed, 08/22/2012 - 01:41
I would suggest to have a look at Imagicle Blue's Attendant:
http://www.imagicle.com/Products/Collaboration/AttendantConsoleandCTI/BluesAttendantEnterprise/tabid/383/language/en-US/Default.aspx
Imagicle  is also part of Cisco portfolio and available on GPL for Call  Accounting and Billing, IP Fax Server and Advanced directories.
Regards.
Christian Bongiovanni
coCEO and CTO
Imagicle Spa
