Warning message
is a faulty AP?
Aug 21st, 2012
I am using WAP4410N access point to connect 5 computer to the network.  Recently the wireless network is very bad; pakets are often being droped, very high reply times. I have upgraded to the latest firmware tried to change configuration with no use i even tried the default configuration.  I assumed that there's interference. I tried another AP ( linksys one) and things seems to be okay. what would be the problem with AP?
Amjad Abdullah Wed, 08/22/2012 - 04:19
  • Red, 2250 points or more
Hammam:
Try changing the channel.
I think you need to do a site survey to check RF status.
hammam.diab Tue, 08/28/2012 - 06:25
I tried all the available channels with no use I even selected auto with apparant effect
Amjad Abdullah Tue, 08/28/2012 - 06:26
Then you need to check your RF spectrum. There could be interference and/or noise.
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
Scott Fella Wed, 08/29/2012 - 05:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Were you able to check the RF... you can just download netstumbler or use some free apps for the android or Apple.
Related Content
