route pattern format question
geraghtyconor
            Hello all,
do these two route patterns give the same result.
Is it just duplication?
0.01511236060 & 6060#
Gordon Ross
Level 9
Level 9
No, they are different.
Guessing slightly here, but the first looks like it's dealing with full PSTN numbers, whereas the second is dealing with just extension numbers.
GTG
Please rate all helpful posts.
It refers to a SIP trunk (a polycom VC sits at the end of it)
it can be dialled from the PSTN or internally
PSTN # = 01511236060
internal extn # = 4006060
I would like to create a router pattern to point the above to the SIP TRK.
