ASA5505 SSC-5 Password Reset Failing
Aug 22nd, 2012
I have tried to reset the password on the SSC-5 module using the command below,but I always fails.
hw-module module 1 password-reset noconfirm
When the SSC-5 comes back online and I try to login using the default username and password of cisco, it fails with Login incorrect.
ASA5505 running version 8.4(4)1 asdm 6.4(9)
IPS version 6.2(4)E4
turnera Wed, 08/22/2012 - 12:31
  • Bronze, 100 points or more
Well, that should have worked. Is is possible that password recovery has been disabled?
If so, then it would look as though the command would work but it will not.
You may have no other choice but to reimage the sensor module.
Related Content
