Warning message
TMS (Server) appliance questions
Answered Question
Aug 22nd, 2012
I have a couple of questions about the TMS server, the stand alone appliance version.
1) I don't recall ever setting an sa password. What is the default?
2) Can I install the Provisioning Extension on the appliance?
thx,
rf
Correct Answer by Justin Ferello about 4 years 12 months ago
rf,
The default SA password on the appliance was 'TANDBERG'.
For question #2, this is the official Cisco response:
Cisco TMSPE may be installed on the now discontinued Cisco TelePresence Management Server, but note that system resources are limited to 2 GB RAM, which will reduce performance. We recommend using the server for small deployments only and ultimately migrating to hardware with more resources available.
Justin
Overall Rating: 5 (1 ratings)
Correct Answer
Justin Ferello Wed, 08/22/2012 - 17:29
  • Bronze, 100 points or more
rf,
Justin
rfrome Wed, 08/22/2012 - 17:37
Justin,
Thanks, that is what I thought it should be, but it seems there are other issues. There is some  "network-related or instance-specific error occurred while establishing a connection to the SQL Server" issue I need to resolve first.
thx
Justin Ferello Wed, 08/22/2012 - 17:38
rf,
Is the TMS application not connecting to the SQL DB?
Justin
rfrome Wed, 08/22/2012 - 17:43
I assumed it was. is there another option for the DB?
Justin Ferello Wed, 08/22/2012 - 17:44
rf,
Where are you seeing that error?
Justin
rfrome Wed, 08/22/2012 - 17:47
I see that error when I try to log into SQl Management Studio express using the credentials sa/TANDBERG
mahkrish Wed, 08/22/2012 - 18:06
Can you give a try logging in using windows authentication in SQL Management Studio express and reset the sa password.
Magnus Ohm Fri, 08/24/2012 - 16:41
  • Cisco Employee,
Did you try to type the correct instance name? Try to enable the sql browser service.
/Magnus
Related Content
