ZBF and VRF
Answered Question
Aug 23rd, 2012
Hello, I'v got simple config, like this
ip vrf LINE
rd 65000:1
zone security LINE
interface GigabitEthernet0/1.206
description -=LINE_UPLINK_ISP=-
encapsulation dot1Q 206
ip vrf forwarding LINE
zone-member security LINE
ip address 195.23x.x.182 255.255.255.252
end
interface GigabitEthernet0/1.207
description -=LINE_PA_SPACE=-
encapsulation dot1Q 207
ip address 195.23x.x.185 255.255.255.248
ip route vrf LINE 0.0.0.0 0.0.0.0 195.239.108.181
No zone-pair for this zone line, no inspection rules configured.
However when user in vlan 207 with address
ip 195.23x.x.186
mask 255.255.255.248
gw 195.23x.x.185
try to connect to Internet, or someone ping from internet to this user, all traffic is denied, when I do
no zone-member security LINE
traffic is passing?
why? I always think that in same zone all traffic allowed
Correct Answer by Julio Carvajal about 4 years 7 months ago
I have been doing my homework with this threath and as I knew the implementation of Intra-Zone policies has been available since 15.1
Here is what I have found interesting so far:
Intrazone Support in the Zone-Based Firewall Application
Intrazone support allows a zone configuration to include users both inside and outside a network. Intrazone support allows traffic inspection between users belonging to the same zone but different networks. Depending on your release, traffic within a zone was allowed to pass uninspected by default. To configure a zone pair definition with the same zone for source and destination, use the zone-pair security command. This allows the functionality of attaching a policy map and inspecting the traffic within the same zone.
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_zbf/configuration/15-2mt/sec-zone-pol-fw.html#GUID-08BAB3A9-DD8A-4656-A887-A38C1EF13512
So It looks like on the newest version in order to allow traffic from a 2 interfaces on the same zone we need to create an intra-zone policy.
I also found the following from the great website of Packetlife.com
http://packetlife.net/blog/2012/jan/30/ios-zone-based-firewall/
In early versions of IOS zone-based firewall, traffic flowing from one interface to another within the same security zone was allowed to pass by default. In recent versions, however, even intra-zone traffic requires a zone pair definition (with a single zone as both the source and destination).
So it will make sense why after I asked you to configure the zone pair it worked
Can you configure an intra-zone pair policy and let me know how it goes
Remember to rate all the helpful posts
Julio
Overall Rating: 5 (1 ratings)
Julio Carvajal Thu, 08/23/2012 - 11:35
  • Purple, 4500 points or more
Hello Kras,
Would you mind to take the logs from the ZBFW
-Ip inspect log drop-pkt
Then just try to connect with the ZBFW configuration in place ofcourse and provide me the logs
Rate all the helpful posts
Krasnoperov Fri, 08/24/2012 - 01:19
here is the log message with ZBF config in place, I tried to connect via ssh to this host
Aug 24 2012 12:16:27.204 MSK: %FW-6-DROP_PKT: Dropping tcp session 95.16x.x.54:51245 195.23x.x.186:22  due to  policy match failure with ip ident 0
Krasnoperov Fri, 08/24/2012 - 02:34
Also, I want to say that rule for ZBF:
As soon as an interface is assigned to a zone, traffic will only flow to interfaces in the same zone.
Works without VRF just fine, but inside VRF it not works for me.
might be it's an IOS bug for:
(C3900-UNIVERSALK9-M), Version 15.2(1)T1, RELEASE SOFTWARE (fc1)
Julio Carvajal Fri, 08/24/2012 - 09:27
And what happens if you leave the VRF setup and you set them on different zones and create an inspection policy to inspect traffic?
Julio
Krasnoperov Sat, 08/25/2012 - 06:37
strange thing happens, when I create second zone and create zone-pair policy, put second interface to this zone and back it to same zone LINE it starts work as I expect, now all config that I post works!
why so?
Julio Carvajal Sat, 08/25/2012 - 10:19
Hello Krasnoperov,
At least is good that is currently working, we could try to perform an upgrade to avoid a bug.
Can I have the version you are running to look for a bug because as you have explained the problem, the behavior does not make sense.
Julio
Krasnoperov Mon, 08/27/2012 - 00:19
Yep, we have two router with identical IOS and identical behavior
System image file is "flash:c3900-universalk9-mz.SPA.152-1.T1.bin"
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 1835264K/261888K
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
Correct Answer
Julio Carvajal Mon, 08/27/2012 - 12:40
Julio
Krasnoperov Wed, 08/29/2012 - 03:22
thanks, Julio
I made zone pair with a policy which pass traffi (just pass no inspection) something like this
zone-pair security LINE->LINE source LINE destination LINE
and traffic starts passing, so I thiks you're right about new IOS and intra-zone pair relations.
It would be grate if I could change this behaviour to default, where rule was:
Is it posible?
Julio Carvajal Wed, 08/29/2012 - 08:25
Hello Krasnoperov,
If you only have a zone-pair for the intra zone traffic then only traffic from the same zone will be allowed so that should do it for you
Julio
Related Content
