Nexus 7K secondary sup in powered-up State
Sunil Patil
I have one Cisco Nexus 7K switch with 2 Sup. In that one sup should be active and anotherone should be ha-standby. But currently secondry is showing powered-up state. Earliyer also we are facing the same issue but after reload the sup the problem got resolved but the same problem occure again.
Please find the below details for same.
HJA_CS01_N7k# sh module Mod  Ports  Module-Type                         Model              Status
1    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
3    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
4    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
5    0      Supervisor module-1X                                   powered-up
6    0      Supervisor module-1X                N7K-SUP1           active *
7    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
8    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
10   48     1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L     ok
Mod  Sw              Hw
1    5.2(1)          1.2
3    5.2(1)          1.2
4    5.2(1)          1.4
6    5.2(1)          2.1
7    5.2(1)          1.4
8    5.2(1)          1.2
10   5.2(1)          1.3
Kindly suggest why its going in powered-up mode in after every 1-2 Months.
krun_shah
Check if there is coredump file using show core command and export to tftp/scp/ftp server.
check comamnd "show system redundancy status". Call Cisco TAC or partner support when you encounter issue again and collect tac-pac.
Leo Laohoo
Duplicate post #1.
