Block Traffic under two VLAN's : Unidirectional OR Bidirectional ???
Kuldeep singh
I have a Ciso L3 switch with 4 VLANs and all host computer connected to rest of 8 cisco 2960 switch's:
VLAN 1  : 192.168.1.0/24
VLAN 10: 192.168.10.0/24
VLAN 20: 192.168.20.0/24
VLAN 50: 192.168.30.0/24
There are list of my some Questions about Extended ACL serialwise :
1. For Restrict traffic from VLAN 10 to VLAN 20, I am using  only one ACL is : Access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255.
    What will happen in this scenerio if we talk about traffic from VLAN 20 to VLAN 10. Will it communicate or not ???
2.   How to Block the traffic from VLAN 10  to  VLAN 20 but allow the traffic from VLAN 20  to  VLAN 10 ? Plz tell access list command for this.
      Question # 2 Depends on Question# 1...................
Plz find here My cisco 3560 switch configuration in Blog below :
Kuldeep
Richard Burts
With your #1 there will be no communication between 20 and 10. Packets from 20 would be able to get to 10 but no response will get back. And with no response there is no communication.
Rick
Rick
19 Replies 19
Hi there,
blocking both ways:
access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
Will it communicate?
With only this acl you will have no full communication between vlan 10 and vlan 20 but the packets/frames from vlan 20 will be allowed. If you do not desire this better to block both ways...
3. Block Traffic from Both side , mean to say, no communication between VLAN 10 to VLAN 20 and VLAN 20 to VLAN 10. what we need to do ??
In all this scenarion i did not get if you implemented inter-vlan routin or not but i guess that the first set of access lists i wrote down will do the job.
Take Care
Alessio
PS: you can use other filters too.. it depends all from your purposes
Hi Alessio.
I have configured intervlan Routing on Cisco 3560 L3 switch....  by Using " ip routing" command
You mean to say, If we will block only traffic from VLAN 10 to VLAN 20 then it will block only VLAN 10 to VLAN 20 but not from VLAN 20 to VLAN 10.  i can access all hosts of VLAN 10 from VLAN 20 Hosts.........
Am i right ????
Plz give answer of  Question Serial No.1 in  Yes or No.............
Sandeep Choudhary
Hi Kuldeep,
1. For Restrict traffic from VLAN 10 to VLAN 20, I am using this : access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255.
Then under the layer3 vlan apply the ACL:
ip access-group 100 in
Solution: It will block both side packet transfer 10<--------->20
2. block the traffic from VLAN 10  to  VLAN 20 but allow the traffic from VLAN 20  to  VLAN 10 ? how many access-list command required, one or two ?
Solution:i hav to find it
3.same as first solution
please rate if it helps.
Blocking all communication between the vlans is easy. Permitting 20 to talk to 10 but not permitting 10 to talk to 20 is tricky. The problem is how to know if a packet from 10 to 20 is a response that should be permitted or originating from 10 which should be denied. With top traffic you use the established parameter to achieve this. With icmp you can do things like permit echo reply but deny echo request. With udp there is not an easy solution. Perhaps you can identify some source port/destination port combinations to permit.
Rick
Rick
Hello All,
i have a question. how can i block printing on subnet or vlan on Cisco switch
i would like to block 172.16.20.1 0.0.3.255 subnet to not print.
the printers ips are 172.16.12.20
172.16.12.21
172.16.12.22
Hi Sandeep,
                   Plz find my cisco 3560 switch configuration for Correct understanding
HI Kuldeep .
IP communication is bidirectional
except for TCP where you could do an ACL  looking for SYN flag, there is no way to accomplish this with a simple ACL.
You'll have to use a stateful firewall( either a router with CBAC or ZBF or an ASA) .
Regards.
Hi Sandeep,
                   You want to say that if we apply ACL to one side then it will be affectable for both side..........
                   Either it be Deny or Permit ?????
                   Am i right ???
As per my knowledge, yes it will affect both side.
Please rate if it helps.
Sir any solution for problem number 2
Richard Burts
Rick
Rick
Hi Richard,
                  See this cisco 3560 switch Configuration, and tell me answers accordingly:
CORE_3560#sh run
Building configuration...
Current configuration : 5299 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname CORE_3560
enable secret 5 $1$d6GO$No/vGsChZP5O.5ANOYI2m/
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
description *** CONNECTING TO CISCO-2960 SWITCH-1 ***
switchport mode trunk
interface Port-channel2
description *** CONNECTING TO CISCO-2960 SWITCH-2 ***
interface GigabitEthernet0/1
channel-group 1 mode on
interface GigabitEthernet0/2
interface GigabitEthernet0/3
channel-group 2 mode on
interface GigabitEthernet0/4
interface GigabitEthernet0/5
description *** CONNECTING TO CISCO-2960 SWITCH-3 ***
interface GigabitEthernet0/6
interface GigabitEthernet0/7
description *** CONNECTING TO CISCO-2960 SWITCH-4 ***
interface GigabitEthernet0/8
interface GigabitEthernet0/9
description *** CONNECTING TO CISCO-2960 SWITCH-5 ***
interface GigabitEthernet0/10
interface GigabitEthernet0/11
description *** CONNECTING TO CISCO-2960 SWITCH-6 ***
interface GigabitEthernet0/12
interface GigabitEthernet0/13
description *** CONNECTING TO CISCO-2960 SWITCH-7 ***
interface GigabitEthernet0/14
description *** CONNECTING TO CISCO-2960 SWITCH-8 ***
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description Connecting to Cisco-1800 Router
switchport access vlan 50
switchport mode access
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1                                     ***** L2 switch's Vlans
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip access-group 101 in
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan50
ip address 192.168.30.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.30.10
ip http server
access-list 101 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 101 permit ip any any
access-list 101 permit icmp any any
control-plane
line con 0
line vty 0 4
password cisco
no login
line vty 5 15
no login
end
Hi Richard,
                 According to you, there will be no communication between VLAN 10 to VLAN 20  and  VLAN 20 to VLAN10.
                 So plz tell me how to block the traffic from VLAN 10  to  VLAN 20 but allow the traffic from  VLAN 20  to
                 VLAN 10 ?
                 Plz send me Access list command for That
                 I am waiting for your Reply
Hi Kuldeep,
as Richard just stated above no bidirectional communication would happen and therefore no connectivity between the hosts in the vlans 10 and 20. I still reccomend to use the bst practises ... that means that should you desire NO communication between these vlans, just type filters in both the directions.
Take Care
Alessio
