router upgrade
Answered Question
Aug 23rd, 2012
I upgraded a 2811 router to the latest version and apparently everything went smooth.   I reloaded and did a sh ver the IOS show the correct version, but the boot strap shows the old IOS.  How can I change the boot strap to show the new IOS
Correct Answer by Peter Paluch about 4 years 11 months ago
Hi Joli,
You seldom, if ever, upgrade the bootstrap on routers. It is not usually upgraded and therefore it is completely normal for the bootstrap - or better said, the ROMMON - to show a different version than the full IOS. The ROMMONs are not released in identical versions to IOSes, and in fact, they are released only to correct some serious errors or limitations of previous versions.
Don't worry about it. It is normal and expected.
Best regards,
Peter
Overall Rating: 5 (2 ratings)
Correct Answer
Peter Paluch Thu, 08/23/2012 - 13:05
  • Cisco Employee,
Hi Joli,
Best regards,
Peter
Leo Laohoo Thu, 08/23/2012 - 15:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The latest bootstrap is 12.4(13r)T11 (April 2010).
One of the major benefits of upgrading to this version is the abililty for the router to boot from supported USB stick.  (Actually USB boot support started from T6, but who's counting anyway.)
If you are still interested, continue reading on.
To download the software go here
To upgrade the ROMmon of the router, just use the very simple command:   upgrade rom-monitor file tftp:///FILENAME
Please be aware that you will be prompted to proceed and when you hit "Y" the router will copy the file and reboot.  This is normal.
Hope this helps.
Joseph W. Doherty Thu, 08/23/2012 - 17:40
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Been a while since I've updated a 2811's ROM, but I recall if you answer "N", not only will the router not reload, you'll have to do the upgrade process again.  I.e. unlike IOS, on this device, you cannot load up the new ROMMOM code and reload later.
Related Content
