Warning message
Multiple SSID no DHCP on guest
Answered Question
Aug 23rd, 2012
I currently have Aironet 1040 AP that I am using stand alone. I am looking to have a second SSID for guest network. only problem I am having is how to get DHCP to those clients?
Correct Answer by Scott Fella about 4 years 12 months ago
That would definitely be a problem. You would not be able to segment the traffic. You would need a managed switch and a router at the minimum.
Overall Rating: 5 (1 ratings)
mcmattcole Fri, 08/24/2012 - 02:31
George,
Thanks for the reply. I do not have any managed switches on this network. I suspect this may be a critical missing piece. I was hoping there was some way to accomplish this using only the AP configuration?
Correct Answer
Scott Fella Fri, 08/24/2012 - 04:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Stephen Rodriguez Fri, 08/24/2012 - 05:20
  • Purple, 4500 points or more
Yes, that would work as it is capable of multiple VLANs.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella Fri, 08/24/2012 - 06:43
  • Hall of Fame,
    2017 Wireless
You just need to make sure you have a router that supports multiple vlans.
mcmattcole Fri, 08/24/2012 - 09:40
So I guess just to make sure I can accomplish this correctly I am attaching a quick diagram of my setup. I have two buildings connected by a wireless bridge. If I place a managed switch on just the side with the firewall is that sufficient or do I need one on both sides?
Scott Fella Fri, 08/24/2012 - 19:49
  • Hall of Fame,
    2017 Wireless
You would need one at each side, if you want to provide both data and guest. The wireless bridge will also have to be able to tag traffic which most do.
