How to set logging on ISE not to UTC timezone
Aug 23rd, 2012
Hello everyone,
I was wondering if there's a way to change the way ISE logs authentications in terms of timezone. I found that it is UTC even if I changed the timezone to my local timezone (PST8PDT).
Tarik Admani Thu, 08/23/2012 - 17:45
  • Green, 3000 points or more
I strongly advise not touching the timezone, it will lead to datbase errors. Please plan on taking a backup and reimage.
Tarik admani
zheka_pefti Thu, 08/23/2012 - 17:59
Wow,
that's insane and crazy. What do you mean not to touch the timezone. It has been already configured during the initial setup.
Tarik Admani Thu, 08/23/2012 - 18:03
You are correct, the time is set before the ise application is installed. The database is primed after to configure ntp dns and basic configuration.
Also the doc recommends using utc.
Tarik
