EEM script to alert on IP SLA failures
burleyman
Level 8
Level 8
I have the following IP SLA set up and would like to do the following. I would like to have a log entry if any of the below have a failure and then send an email alerting to that failure. Is there a way to do this with EEM?
ip sla 1010
udp-jitter 64.xxx.xxx.xxx 3456 num-packets 30 interval 25
history hours-of-statistics-kept 24
ip sla schedule 1010 life forever start-time now
ip sla 1011
tcp-connect 64.xxx.xxx.xxx 2000
ip sla schedule 1011 life forever start-time now
ip sla 1012
icmp-echo 64.xxx.xxx.xxx
frequency 30
history distributions-of-statistics-kept 10
ip sla schedule 1012 life forever start-time now
Mike
Joe Clarke
Sure.  You can use Enhanced Object Tracking to track each IPSLA collector and have EEM react to timeouts.  For example:
track 1 ip sla 1010 reachability
event manager applet track-1010
event track 1 state down
action 1.0 syslog msg "IPSLA collector 1010 timed out"
action 2.0 mail from "user@example.com" to "user@example.com" subject "IPSLA Collector 1010 is down" body "IPSLA Collector 1010 has timed out" server "10.1.1.1"
Joe Clarke
Thanks that is very helpful. Now what about something like this?
From below I would like to alert if there is a failure (see the bold)
IP_SLA_2821#show ip sla stat 1020
IPSLAs Latest Operation Statistics
IPSLA operation id: 1020
Type of operation: udp-jitter
Latest RTT: 23 milliseconds
Latest operation start time: 14:25:34.377 EDT Fri Aug 24 2012
Latest operation return code: OK
RTT Values:
Number Of RTT: 30  RTT Min/Avg/Max: 23/23/33 milliseconds
Latency one-way time:
Number of Latency one-way Samples: 30
Source to Destination Latency one way Min/Avg/Max: 9/10/16 milliseconds
Destination to Source Latency one way Min/Avg/Max: 13/13/23 milliseconds
Jitter Time:
Number of SD Jitter Samples: 29
Number of DS Jitter Samples: 29
Source to Destination Jitter Min/Avg/Max: 0/1/6 milliseconds
Destination to Source Jitter Min/Avg/Max: 0/1/10 milliseconds
Packet Loss Values:
Loss Source to Destination: 0  Loss Destination to Source: 0
Out Of Sequence: 0 Tail Drop: 0
Packet Late Arrival: 0 Packet Skipped: 0
Voice Score Values:
Calculated Planning Impairment Factor (ICPIF): 0
Mean Opinion Score (MOS): 0
Number of successes: 33
Number of failures: 0
Operation time to live: Forever
That's what the EOT example I gave should give you.
Sorry, I misunderstood. I thought it was just for the ICMP and would be different for the others. Thank you for your help and I will try it out.
Mike
