Warning message
Sup7L-E - How to select "1-Gigabit Operation"?
Answered Question
Aug 24th, 2012
Documentation discusses "1-Gigabit Operation", where all 4 1-Gig SFP's on Sup7L-E are enabled.   But it does not say __how__ to select either 10-G or 1-G operational modes.
Please help!   I have searched & searched, & cannot find any mention of how to do this.
thanks in advance....
Correct Answer by krahmani323 about 4 years 11 months ago
Hello Lorraine,
From the release notes
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_25346.html#wp2552887
" Supervisor  Engine 7L-E has two modes (One-Gigabit and Ten-Gigabit), which can be  changed from Ten-Gigabit to One-Gigabit, or One-Gigabit to 10-Gigabit by  entering the hw-module uplink select [gigabitethernet | tengigabitethernet] command and then reloading the shelf . By default, Supervisor Engine 7L-E is in Ten-Gigabit mode"
Also :
"Supervisor Engine 7L-E supports two Ten-Gigabit  ports in Ten-Gigabit mode and four One-Gigabit ports in One Gigabit mode  non blocking. SFP+ transceivers are not be supported in 1 Gigabit mode."
Best regards.
Karim
Overall Rating: 5 (1 ratings)
lorrainecamp Fri, 08/24/2012 - 17:11
finally found it.
Syntax is,
conf t
hw-module uplink select gigabitethernet
end
msg is generated:
"A reload o fthe active supervisor is required to apply the new configuration."
Correct Answer
krahmani323 Fri, 08/24/2012 - 17:12
  • Silver, 250 points or more
Hello Lorraine,
Also :
Best regards.
Karim
lorrainecamp Fri, 08/24/2012 - 17:16
I had found the answer, only one minute before you replied  -   but I appreciate your response, all the same!
thanks, and have a nice weekend
