can't get stateful failover on active/backup load balancers to work (CSS11501)
harriet82
Hi everyone,
Having some issues with load balancing two webservers using two CSS11501 content service switches (VIP/interface redundancy, Active/Backup, and Active Session Redundancy setup).
I've set up both CSSs to load balance the web servers behind it, and it works with Active/Backup setup.  When I configure it with Active Session Redundancy though for stateful failover, I start to have issues.  For example, as a test, I'm downloading a file through the load balancers from the web server.  Mid-download, when I do a reboot on the master CSS, the download just suddenly stops (meaning, my ASR stateful config didn't work.. duhh). the funny thing is this: after the CSS finishes rebooting, and both are up again, I can't access the web servers through vip address at all (times out on my web browser).  To get it up and running again, I would first need to unplug the ethernet cables from the master CSs, wait awhile, then re-attach.
I've tried many variations on fixing this issue, but have been unsuccessful.  Any help is appreciated.  I've attached the running config on both CSSs for your reference (i've chnaged the IPs around, of course, but you get the idea):
CSS 1:
!*************************** GLOBAL ***************************
  global-portmap base-port 3000 range 30000
!************************* INTERFACE *************************
interface e2
  bridge vlan 2
interface e7
  isc-port-one
!************************** CIRCUIT **************************
circuit VLAN1
  ip address 172.41.2.2 255.255.255.0
    ip virtual-router 1
    ip redundant-interface 1 172.41.2.254
circuit VLAN2
  ip address 215.215.186.10 255.255.255.0
    ip virtual-router 2
    ip redundant-interface 2 215.215.186.254
    ip redundant-vip 2 215.215.186.5
    ip redundant-vip 2 215.215.186.3
!************************** SERVICE **************************
service ws1-80
  ip address 172.41.2.10
  keepalive type http
  keepalive port 80
  protocol tcp
  redundant-index 1
  active
service ws2-80
  ip address 172.41.2.11
  keepalive type http
  keepalive port 80
  protocol tcp
  redundant-index 2
  active
!*************************** OWNER ***************************
owner company1
  content ws80-newvip
    vip address 215.215.186.5
    protocol tcp
    port 80
    add service ws1-80
    add service ws2-80
    redundant-index 102
    active
  content ws80-oldvip
    protocol tcp
    vip address 215.215.186.3
    port 80
    add service ws1-80
    add service ws2-80
    redundant-index 101
    active
CSS2:
sh run
  global-portmap base-port 33100 range 30000
interface e2
  bridge vlan 2
interface e7
  isc-port-one
circuit VLAN1
  ip address 172.41.2.3 255.255.255.0
    ip virtual-router 1
circuit VLAN2
  ip address 215.215.186.11 255.255.255.0
    ip virtual-router 2
service ws1-80
  keepalive type http
  keepalive port 80
  protocol tcp
  redundant-index 1
  active
service ws2-80
  keepalive type http
  keepalive port 80
  protocol tcp
  redundant-index 2
  active
owner company1
  content ws80-newvip
    port 80
    protocol tcp
    add service ws1-80
    add service ws2-80
    redundant-index 102
    active
  content ws80-oldvip
    protocol tcp
    port 80
    add service ws1-80
    add service ws2-80
    redundant-index 101
    active
harriet82
just to add to the previous post, i didn't configure any critical services - but I don't believe this should be an issue.  You can see in the configuration.  As well, I don't have any issues with both CSSs failing over when I have both up and running, and I manually power down / or simply unplug one CSS... it fails over well from master to backup and vice versa.
I only have an issue when i reboot one CSS - it never seems to recover when I reboot, even after the one CSS comes back up.
Thanks again,
Harriet
