Warning message
1041n Access Point Performance
Aug 25th, 2012
I purchased a new ap1041n access point. It's the first Cisco I've tried to configure in a long time. I'm trying to get the 802.11n working but it seems to be stuck in 802.11G since I can only get it to go up to 36mb. The radio says its running in mixed mode and I can't figure out if that means b/g or b/g/n. I ran the Express Setup and it didn't seem to help me. I'm hoping it's an easy fix. I posted the config below, if anyone can help me it would be greatly appreciated.
version 12.4
no service pad
service password-encryption
hostname AP
logging rate-limit console 9
enable secret 5 $1$36ve$pm3oh52Ka.KyxGeMa9W7C1
no aaa new-model
ip domain name hyrule
dot11 syslog
dot11 ssid Test
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 1521040F0B0B26253A3621361C2B1F0E04
   no ids mfp client
username
username
ip ssh version 1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid UNSC
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.10.0.251 255.255.255.0
no ip route-cache
ip default-gateway 10.10.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
login local
end
Leo Laohoo Sat, 08/25/2012 - 20:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
For 802.11n, use either OPEN authentication or WPA2/AES or PSK.
baroncubed Sat, 08/25/2012 - 21:30
Ok, after I enabled wpa2 what do I need to do in order to enable 802.11n?
Leo Laohoo Sat, 08/25/2012 - 21:59
  • Hall of Fame,
    2017 LAN, Wireless
Test it using a KNOWN 802.11n-capable wireless NIC.
Do NOT use smartphones or tablets.  Use a laptop.
baroncubed Sun, 08/26/2012 - 05:30
Ok, on my Dell Precision with an Intel 5100 agn wireless nic the link speed tops out at 72mbps and I checked on a different laptop with an N wireless nic and it also topped out at 72mb and that's sitting right next to the access point.
Edit: Ok the Intel 5100 is apparently just crap, I set it to 20mhz only instead of auto and now it's connecting at 144mbps which is closer to what I expected. My understanding is that I can't get the full 300mbps without a MIMO card.
Leo Laohoo Sun, 08/26/2012 - 15:49
  • Hall of Fame,
    2017 LAN, Wireless
Check the link below, see if you are running the latest wi-fi NIC card drivers.
Intel 5100 Wi-Fi drivers
Related Content
