WLC 5508 Software 7.2.103.0 to 6.0.199.4 is possible to degrade
Aug 25th, 2012
  Hi i got my first WLC 5508 with software 6.0.199.4 and i deployed in site and the branches i have started registring AP's HREAP mode.
And its working fine .
The second WLC came with software 7.2.103.0 so i doubt if i connect this WLC IN one of the site so it will be a issue .
So whats the best practice. is it possible to Downgrade the second WLC to 6.0 version
Leo Laohoo Sat, 08/25/2012 - 23:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes you can but WHY?
You're question is slightly "incorrect".  7.2.X has slightly more features so do consider the option to upgrade the first WLC from 6.0.X to 7.2.103.0 or even 7.2.110.0 instead.
Amjad Abdullah Sun, 08/26/2012 - 01:05
  • Red, 2250 points or more
You better upgrade both WLCs to the latest version. Besides the bug fixes that you get, there are many new features in 7.0 than 6.0. also, 7.2 is having more features than 7.0.
If you want anyway to downgrade, that is possible. But you may lose your configuratoin. so you need to take the precautions and get a backup before the downgrade.
Amjad
You want to say "Thank you"? Don't. Just rate the useful answers, that is more useful than "Thank you".
fbarboza Mon, 08/27/2012 - 06:20
  • Bronze, 100 points or more
As explained above the code 7.2.103.0 has more features than the 6.0.199.4 also on code 6.0.199.4 that is software problem that the wireless clients are not able to get an IP address from the DHCP server if the DHCP server is the WLC.
If you downgrade the code of the WLC from 7.2.103.0 to 6.0.199.4 the configuration may get lost so as advices make sure to make a back up.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
